Do you have a link to the Device Handler so I can see what kind of a device that is?
Device Status Tiles
yes i updated to it but it is just sat like this. But its not giving loads of errors like the old one was.
I have five Halo devices in the house and this is what I have after installing and waiting the 10m for the 1st processing to execute:
Looks good except I get a lot of errors in the log ⦠tons of $device not found errors?
Here is my device config from the piston - nothing else changed:
| +1ms | āReceived event [Home].time = 1516747103595 with a delay of -1071ms |
| +124ms | āRunTime Analysis CS > 18ms > PS > 32ms > PE > 74ms > CE |
| +128ms | āRuntime (76994 bytes) successfully initialized in 32ms (v0.2.102.20180116) (126ms) |
| +129ms | āāExecution stage started |
| +171ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +203ms | āāComparison (boolean) is_not (boolean) true = true (3ms) |
| +205ms | āāCondition #273 evaluated true (8ms) |
| +206ms | āāCondition group #270 evaluated true (state did not change) (9ms) |
| +208ms | āāCancelling statement #271ās schedules⦠|
| +216ms | āāExecuted virtual command setVariable (4ms) |
| +220ms | āāCancelling statement #255ās schedules⦠|
| +236ms | āāExecuted virtual command setVariable (4ms) |
| +242ms | āāCalculating (integer) 0 + (integer) 1 >> (integer) 1 |
| +246ms | āāExecuted virtual command setVariable (2ms) |
| +640ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +662ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +684ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +695ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +723ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +746ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +767ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +779ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +804ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +825ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +847ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +859ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +877ms | āāCalculating (boolean) false == (boolean) false >> (boolean) true |
| +902ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +921ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +939ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +950ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +972ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +991ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1009ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1020ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1043ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +1063ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +1083ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +1095ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +1128ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1149ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1169ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1180ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1201ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1219ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1238ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1249ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1256ms | āāExecuted virtual command setTile (1ms) |
| +1271ms | āāComparison (boolean) null is_not (boolean) true = true (1ms) |
| +1272ms | āāCondition #273 evaluated true (7ms) |
| +1273ms | āāCondition group #270 evaluated true (state did not change) (8ms) |
| +1275ms | āāCancelling statement #271ās schedules⦠|
| +1281ms | āāExecuted virtual command setVariable (3ms) |
| +1285ms | āāCancelling statement #255ās schedules⦠|
| +1290ms | āāExecuted virtual command setVariable (2ms) |
| +1296ms | āāCalculating (integer) 1 + (integer) 1 >> (integer) 2 |
| +1300ms | āāExecuted virtual command setVariable (2ms) |
| +1328ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1350ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1370ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1381ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1403ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1422ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1440ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1451ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1473ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +1491ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +1510ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +1521ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +1538ms | āāCalculating (boolean) false == (boolean) false >> (boolean) true |
| +1564ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1589ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1611ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1623ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1649ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1671ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1695ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1708ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1733ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +1754ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +1776ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +1788ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +1821ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1841ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1861ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1872ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1893ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +1912ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +1931ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +1943ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +1951ms | āāExecuted virtual command setTile (2ms) |
| +1966ms | āāComparison (boolean) null is_not (boolean) true = true (2ms) |
| +1968ms | āāCondition #273 evaluated true (7ms) |
| +1969ms | āāCondition group #270 evaluated true (state did not change) (9ms) |
| +1971ms | āāCancelling statement #271ās schedules⦠|
| +1978ms | āāExecuted virtual command setVariable (3ms) |
| +1981ms | āāCancelling statement #255ās schedules⦠|
| +1987ms | āāExecuted virtual command setVariable (2ms) |
| +1993ms | āāCalculating (integer) 2 + (integer) 1 >> (integer) 3 |
| +1998ms | āāExecuted virtual command setVariable (3ms) |
| +2038ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +2070ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +2098ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +2112ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +2141ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +2165ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +2191ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +2204ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +2233ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +2253ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +2277ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +2288ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +2307ms | āāCalculating (boolean) false == (boolean) false >> (boolean) true |
| +2333ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +2353ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +2374ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +2385ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +2409ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +2429ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +2449ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +2462ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +2486ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +2505ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +2525ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +2717ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +2768ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +2795ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +2819ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +2830ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +2851ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +2872ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +2893ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +2904ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +2913ms | āāExecuted virtual command setTile (1ms) |
| +2928ms | āāComparison (boolean) null is_not (boolean) true = true (2ms) |
| +2930ms | āāCondition #273 evaluated true (7ms) |
| +2931ms | āāCondition group #270 evaluated true (state did not change) (9ms) |
| +2935ms | āāCancelling statement #271ās schedules⦠|
| +2943ms | āāExecuted virtual command setVariable (3ms) |
| +2947ms | āāCancelling statement #255ās schedules⦠|
| +2954ms | āāExecuted virtual command setVariable (2ms) |
| +2960ms | āāCalculating (integer) 3 + (integer) 1 >> (integer) 4 |
| +2965ms | āāExecuted virtual command setVariable (3ms) |
| +3000ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +3026ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +3048ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +3060ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +3095ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +3117ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +3139ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +3152ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +3181ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +3204ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +3227ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +3240ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +3260ms | āāCalculating (boolean) false == (boolean) false >> (boolean) true |
| +3286ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +3312ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +3354ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +3368ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +3394ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +3413ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +3432ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +3443ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +3466ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +3485ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +3505ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +3516ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +3550ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +3573ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +3594ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +3606ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +3634ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +3660ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +3891ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +3904ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +3912ms | āāExecuted virtual command setTile (2ms) |
| +3929ms | āāComparison (boolean) null is_not (boolean) true = true (2ms) |
| +3931ms | āāCondition #273 evaluated true (8ms) |
| +3932ms | āāCondition group #270 evaluated true (state did not change) (9ms) |
| +3934ms | āāCancelling statement #271ās schedules⦠|
| +3942ms | āāExecuted virtual command setVariable (5ms) |
| +3947ms | āāCancelling statement #255ās schedules⦠|
| +3956ms | āāExecuted virtual command setVariable (3ms) |
| +3964ms | āāCalculating (integer) 4 + (integer) 1 >> (integer) 5 |
| +3969ms | āāExecuted virtual command setVariable (2ms) |
| +4001ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +4022ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +4041ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +4052ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +4076ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +4096ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +4119ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +4131ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +4158ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +4180ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +4200ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +4211ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +4238ms | āāCalculating (boolean) false == (boolean) false >> (boolean) true |
| +4267ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +4288ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +4311ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +4326ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +4356ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +4376ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +4395ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +4405ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +4427ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +4446ms | āāCalculating (string) device ā$deviceā not found == (string) tested >> (boolean) false |
| +4464ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +4475ms | āāCalculating (boolean) true == (boolean) true >> (boolean) true |
| +4504ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +4523ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +4541ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +4552ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +4573ms | āāCalculating (string) device ā$deviceā not found == (string) detected >> (boolean) false |
| +4598ms | āāCalculating (string) device ā$deviceā not found == (string) warning >> (boolean) false |
| +4621ms | āāCalculating (string) device ā$deviceā not found == (string) emergency >> (boolean) false |
| +4632ms | āāCalculating (boolean) false == (boolean) true >> (boolean) false |
| +4640ms | āāExecuted virtual command setTile (2ms) |
| +4645ms | āāCancelling statement #263ās schedules⦠|
| +4652ms | āāExecuted virtual command setVariable (3ms) |
| +4671ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4679ms | āāCancelling statement #266ās schedules⦠|
| +4684ms | āāExecuted virtual command clearTile (1ms) |
| +4700ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4707ms | āāCancelling statement #266ās schedules⦠|
| +4711ms | āāExecuted virtual command clearTile (1ms) |
| +4730ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4737ms | āāCancelling statement #266ās schedules⦠|
| +4741ms | āāExecuted virtual command clearTile (1ms) |
| +4758ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4764ms | āāCancelling statement #266ās schedules⦠|
| +4769ms | āāExecuted virtual command clearTile (1ms) |
| +4784ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4790ms | āāCancelling statement #266ās schedules⦠|
| +4794ms | āāExecuted virtual command clearTile (1ms) |
| +4811ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4817ms | āāCancelling statement #266ās schedules⦠|
| +4821ms | āāExecuted virtual command clearTile (0ms) |
| +4836ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4841ms | āāCancelling statement #266ās schedules⦠|
| +4845ms | āāExecuted virtual command clearTile (1ms) |
| +4860ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4865ms | āāCancelling statement #266ās schedules⦠|
| +4869ms | āāExecuted virtual command clearTile (1ms) |
| +4883ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4889ms | āāCancelling statement #266ās schedules⦠|
| +4893ms | āāExecuted virtual command clearTile (1ms) |
| +4908ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4914ms | āāCancelling statement #266ās schedules⦠|
| +4917ms | āāExecuted virtual command clearTile (0ms) |
| +4932ms | āāCalculating (integer) 5 + (integer) 1 >> (integer) 6 |
| +4938ms | āāCancelling statement #266ās schedules⦠|
| +4941ms | āāExecuted virtual command clearTile (0ms) |
| +4949ms | āāExecution stage complete. (4820ms) |
| +4951ms | āSetting up scheduled job for Tue, Jan 23 2018 @ 5:48:23 PM EST (in 596.12s) |
| +4957ms | āEvent processed successfully (4957ms) |
Really odd, webCoRE is getting a True statement from the Testing Variable when using the isTesting Attribute even for me without a Nest Smoke Detector. The Nest DTH has a isTesting Attribute whenever it was tested which is why I have that there.
Iāll look into that deeper and let you know once I have a solution, thanks for pointing that out.
Edit
I fixed both issues, figured out $device wasnāt set right when setting the DeviceType variable and fixed both issues for me including those $device not found errors. Please also test using the test button on your Nest Protect to verify itās fully working so I can verify Iām using the correct attribute.
I updated the Wiki but you can import code: hzug without having to goto the Wiki link.
I donāt have a camera myself to test with, I may get one later this year and could look to create a tile but itās impossible without being able to test it myself. If you search this site, youāll find how others has created tiles that actually displays their camera feed.
Example:
I wasnāt sure if thatās what you are looking for exactly, if not explain what you want to be displayed actually on the tile.
Thanks!
I will give this a shot when I am home alone at some point this weekend ⦠testing the interconnected Halo devices sets the entire house off and well ⦠WAF
I can confirm that I sent a test event from NST manager and it all worked! It now says test im guessing on the next pole it will go to normal? Thanks @bfara83
Correct, it should update back to the inactive status on itās own or within the update interval set (default 10 mins)
hello everyone!
so i followed the steps outlined here:
and looks like i now have two instances
and created presence sensor tiles outlined here:
https://wiki.webcore.co/Device_Tiles#Presence_Sensor_Status_Tiles
i however am not seeing this end result
am i missing a step? or where should i go to see the tiles? am supposed to go to the dashboard of the webcore tiles that i created correct?
when i do go to the webcore tiles dashboard, i see this.
Hi macombweare,
The tiles display on the dashboard site where all of your pistons are displayed at but from your screenshot above, you donāt have your piston setup on a category that displays the tiles. It looks like you are going the Dashboard which displays the device statuses of all of your devices instead of displaying any tiles that are setup on your Pistons. Create a category first by going to settings on the left side, click on Categories option on top then create a category with the Tiles option selected on the dropdown besides the category you created.
Example of mine:
Thereās several options for Tiles, any of the category types with Tiles will work, you can play around with the different size tiles:
Tiles and Details options will display the Piston List and the Tiles if you prefer to display it that way.
Once this is done, open your piston again and select that category that you created under Piston Category dropdown:
Example of my Door Lock Status Piston that is in the Device Status Tiles category:
thanks. though not the result i wanted, i did get it going
i started with presence sensors and was hoping to see AWAY or PRESENT status⦠ill tinker some moreā¦
thanks again.
What displays on the tiles can also be changed if you wish, you can have it show Away and Home in text form if you modify these variables on the top:
Right now it displays Font Awesome icons which is what the :fa-home: and :fa:user: is on that variable.
Full list of Font Awesome icons: http://fontawesome.io/cheatsheet/
When using webCoRe Presence Sensor, itāll display the Place Name instead.
My apologies if I missed it I. This thread but can you do anything like this in webCoRE? This was done using freeboard.
GRClark: You can have gauges instead of the tiles in webCoRE although doesnāt look exactly like your screenshot (search for gauge on the top of this site to find posts for examples). For the Temp History on your screenshot, you can setup Fuel Streams as well (search this site for examples as well).
Is there a way to change the background color of WebCore?
Is there a way to link directly to one of the WebCore instances (URL to my webcore tiles instance)?
Can someone please tell me how to ONLY display temperature and not humidity in this piston
Backup code: 8792 from here: https://wiki.webcore.co/Device_Tiles#Temperature.5CHumidity_Status_Tiles
Currently it displays both temp and humidity, and I just want temp.
This is the applicable code:
[$currentEventDevice:humidity]>0 ? ({Convert2Celsius} == ātrueā ? celsius({format(ā%.0fā, decimal([$currentEventDevice:temperature]))})ā°Cā : ā{format(ā%.0fā, decimal([$currentEventDevice:temperature]))}{TempDisplay}āā ā"{format(ā%.0fā, decimal([$currentEventDevice:humidity]))}%") :
({Convert2Celsius} == ātrueā ? celsius({format(ā%.0fā, decimal([$currentEventDevice:temperature]))})ā°Cā : ā{format(ā%.0fā, decimal([$currentEventDevice:temperature]))}{TempDisplay}ā)
Edit: could someone explain what is going on here with this code? What are the == doing? Is that > 0 ? phrase a funky way of writing an if statement? not a coder
I did like the idea of the toggle
