Never mind, realised it’s just that you pick “are” and it says “is”. I was thinking they were different tests.
When I edit a piston then save the change never shows in the dashboard code but if you click on the code line the change has been made.
The first jpg shows the contents of the dialog box and the second jpg shows.
I did a save and came back in but the condition exists still. Logged out and back in same thing.
Not sure how you could replicate this bug as I have never had it before.
