+213ms ║║Error executing virtual command [].sendNotificationToContacts: (13ms) java.lang.NullPointerException: Cannot get property 'translatedMessage' on null object
A text notification is sent to the expected users.
The alarm arms in away, and location mode is set to Away, but the notification is not sent.
2/15/2018, 7:48:03 AM +201ms
+1ms ╔Received event [Rozzly Home].alarmSystemStatus = away with a delay of 44ms
+10124ms ║Piston waited at a semaphore for 10018ms
+10127ms ║Runtime (39864 bytes) successfully initialized in 10032ms (v0.2.102.20180116) (10126ms)
+10128ms ║╔Execution stage started
+10133ms ║╚Execution stage complete. (5ms)
+10134ms ╚Event processed successfully (10134ms)
2/15/2018, 7:48:03 AM +1ms
+1ms ╔Received event [1 iPhone (BETA)].presence = not present with a delay of 94ms
+111ms ║Runtime (39795 bytes) successfully initialized in 21ms (v0.2.102.20180116) (109ms)
+160ms ║║Executed virtual command setAlarmSystemStatus (8ms)
+196ms ║║Executed virtual command setLocationMode (34ms)
+217ms ║╚Execution stage complete. (104ms)
+218ms ╚Event processed successfully (218ms)
2/15/2018, 7:46:06 AM +969ms
+1ms ╔Received event [2 iPhone (BETA)].presence = not present with a delay of 107ms
+120ms ║Runtime (39791 bytes) successfully initialized in 26ms (v0.2.102.20180116) (118ms)
+152ms ║╚Execution stage complete. (31ms)
+153ms ╚Event processed successfully (152ms)
2/15/2018, 7:44:41 AM +846ms
+0ms ╔Received event [3 iPhone (BETA)].presence = not present with a delay of 113ms
+95ms ║Runtime (39788 bytes) successfully initialized in 16ms (v0.2.102.20180116) (94ms)
+128ms ║╚Execution stage complete. (32ms)
+129ms ╚Event processed successfully (130ms)
It seems this is also affecting my other pistons.
2/15/2018, 7:29:59 AM +104ms
+0ms ╔Received event [Rozzly Home].time = 1518697800000 with a delay of -897ms
+154ms ║Error executing virtual command [All Outside Lights].sendNotificationToContacts: (17ms) java.lang.NullPointerException: Cannot get property 'translatedMessage' on null object
+162ms ║Setting up scheduled job for Thu, Feb 15 2018 @ 6:13:00 PM EST (in 38580.735s), with 1 more job pending
+170ms ╚Event processed successfully (169ms)
2/14/2018, 6:11:59 PM +220ms
+1ms ╔Received event [Rozzly Home].time = 1518649920000 with a delay of -780ms
+220ms ║Error executing virtual command [All Outside Lights].sendNotificationToContacts: (13ms) java.lang.NullPointerException: Cannot get property 'translatedMessage' on null object
+226ms ║Setting up scheduled job for Thu, Feb 15 2018 @ 7:30:00 AM EST (in 47880.555s), with 1 more job pending
+234ms ╚Event processed successfully (234ms)
2/14/2018, 7:30:59 AM +115ms
+0ms ╔Received event [Rozzly Home].time = 1518611460000 with a delay of -886ms
+146ms ║Error executing virtual command [All Outside Lights].sendNotificationToContacts: (17ms) java.lang.NullPointerException: Cannot get property 'translatedMessage' on null object
+151ms ║Setting up scheduled job for Wed, Feb 14 2018 @ 6:12:00 PM EST (in 38460.734s), with 1 more job pending
+158ms ╚Event processed successfully (158ms)
2/13/2018, 6:10:59 PM +279ms
+1ms ╔Received event [Rozzly Home].time = 1518563460000 with a delay of -721ms
+254ms ║Error executing virtual command [All Outside Lights].sendNotificationToContacts: (42ms) java.lang.NullPointerException: Cannot get property 'translatedMessage' on null object
+259ms ║Setting up scheduled job for Wed, Feb 14 2018 @ 7:31:00 AM EST (in 48000.463s), with 1 more job pending
+266ms ╚Event processed successfully (266ms)
2/13/2018, 7:31:59 AM +71ms
+0ms ╔Received event [Rozzly Home].time = 1518525120000 with a delay of -930ms
+139ms ║Setting up scheduled job for Tue, Feb 13 2018 @ 6:11:00 PM EST (in 38340.791s), with 1 more job pending
+147ms ╚Event processed successfully (147ms)
2/12/2018, 6:08:59 PM +189ms
+1ms ╔Received event [Rozzly Home].time = 1518476940000 with a delay of -811ms
+285ms ║Setting up scheduled job for Tue, Feb 13 2018 @ 7:32:00 AM EST (in 48180.526s), with 1 more job pending
+295ms ╚Event processed successfully (295ms)
