I have been using the AT_Presence Webcore/Smartthings/ActionTiles setup for nearly a year. Webcore backup bin code h6fo. Recently starting receiving the following error for the https get requests which stores the data on my server.
Error executing external web request: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
I can manually enter the URL successfully and update the database. I have seperate pistons for my 4 family members, each has the error. I do not believe this is a piston code error, but a webcore functionality error. My host is hostgator, and my HTTPS cert is up to date. Thanks for any incite!
