Removed the piston that uses the Sensibo with the device "Pod Toshiba"
Same result, triggers film time.
Removed the device from the instance, did cleanup inn all 3 instances.
It still triggers the “Film Time” piston.
Found in log, 1 the Sensibo logs, then the Sensibo connect logs, then the piston fires.
More logs from live log:
c29854e3-cbcd-4fc7-a4f9-3fb342c55156 21:52:54: error physicalgraph.exception.StateCharacterLimitExceededException: State cannot be greater than 100000.0 characters
c29854e3-cbcd-4fc7-a4f9-3fb342c55156 21:52:49: error physicalgraph.exception.StateCharacterLimitExceededException: State cannot be greater than 100000.0 characters
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: info ╔ Event processed successfully (440ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: trace ║╔ Execution stage complete. (67ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Comparison (string) null executes (integer) 1 = false (2ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition group #29 evaluated false (state did not change) (6ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition #33 evaluated false (5ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition group #7 evaluated false (state did not change) (11ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Comparison (string) :5a09efd6af50a1f6822c8fb8a0090bb2: changes_to (string) :5a09efd6af50a1f6822c8fb8a0090bb2: = false (0ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition group #24 evaluated false (state did not change) (7ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition #11 evaluated false (9ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition #28 evaluated false (7ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition group #1 evaluated false (state did not change) (12ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Comparison (string) :5a09efd6af50a1f6822c8fb8a0090bb2: is (string) :68400df17c8f61373c3ef923d920b273: = false (2ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║║ Condition #6 evaluated false (10ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: trace ║╚ Execution stage started
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: trace ║ Runtime (46807 bytes) successfully initialized in 132ms (v0.2.0e7.20170906) (364ms)
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:46: info ╚ Received event [Pod Toshiba].mode = heat with a delay of 196ms
2e60fca8-16eb-4fc1-9730-b860402e4ebc 21:52:47: debug ║ RunTime Analysis CS > 73ms > PS > 132ms > PE > 152ms > CE
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :battery value :100
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :thermostatMode value :off
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :Error value :Success
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :thermostatFanMode value :auto
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :switch value :off
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :fanLevel value :auto
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :swing value :stopped
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :targetTemperature value :24
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :voltage value :3000
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :temperatureUnit value :C
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :humidity value :38.2
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug parsing Event data [targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :heatingSetpoint value :24
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug parsing data [targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Error in Poll Success, displayed:false]
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :mode value :heat
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :temperature value :24.3
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:TEST TEST [data:[targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]], displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug updating dni uvwVRbxg
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug product Model : skyv2
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug name :coolingSetpoint value :24
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Current Time = 1505418766345, displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug [targetTemperature:24, temperatureUnit:C, fanLevel:auto, on:false, swing:stopped, mode:heat]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:polled children and looking for uvwVRbxg from [uvwVRbxg:[data:[targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]]], displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Response from Sensibo GET = [result:[[status:Success, acState:[targetTemperature:24, temperatureUnit:C, fanLevel:auto, on:false, swing:stopped, mode:heat], device:[isGeofenceOnExitEnabled:false, shouldShowFilterCleaningNotification:false, location:[id:M3yqs3YwKY, createTime:[time:2017-09-11T18:32:10Z, secondsAgo:264036], address:[Vestbygata 52B, 2003 Lillestrøm, Norway], updateTime:[time:2017-09-13T14:28:01Z, secondsAgo:105885], latLon:[59.9638025, 11.04170703125], country:Norway], acState:[targetTemperature:24, temperatureUnit:C, fanLevel:auto, on:false, swing:stopped, mode:heat], productModel:skyv2, id:uvwVRbxg, measurements:[time:[time:2017-09-14T19:52:45.884000Z, secondsAgo:0], humidity:38.2, rssi:-24, piezo:[null, null], batteryVoltage:null, temperature:24.3], connectionStatus:[lastSeen:[time:2017-09-14T19:52:45.884000Z, secondsAgo:0], isAlive:true], configGroup:stable, firmwareVersion:IN010050, remoteCapabilities:[modes:[cool:[fanLevels:[low, medium_low, medium, medium_high, high, auto], temperatures:[F:[values:[63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86], isNative:false], C:[values:[17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30], isNative:true]], swing:[stopped, rangeFull]], dry:[swing:[stopped, rangeFull], temperatures:[F:[values:[63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86], isNative:false], C:[values:[17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30], isNative:true]]], auto:[fanLevels:[low, medium_low, medium, medium_high, high, auto], temperatures:[F:[values:[63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86], isNative:false], C:[values:[17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30], isNative:true]], swing:[stopped, rangeFull]], fan:[fanLevels:[low, medium_low, medium, medium_high, high, auto], temperatures:[:], swing:[stopped, rangeFull]], heat:[fanLevels:[low, medium_low, medium, medium_high, high, auto], temperatures:[F:[values:[63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86], isNa…[TRUNCATED]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug polled children and looking for uvwVRbxg from [uvwVRbxg:[data:[targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]]]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug updated 1 stats: [data:[targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Event Data = [temperature:24.3, humidity:38.2, targetTemperature:24, fanLevel:auto, mode:heat, on:off, switch:off, thermostatMode:off, thermostatFanMode:auto, coolingSetpoint:24, heatingSetpoint:24, temperatureUnit:C, voltage:3000, swing:stopped, battery:100, powerSource:mains, productModel:skyv2, firmwareVersion:IN010050, Error:Success], displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Response from Sensibo GET = [result:[[time:[time:2017-09-14T19:52:45.884000Z, secondsAgo:0], humidity:38.2, batteryVoltage:null, temperature:24.3]], status:success], displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug On: off targetTemp: 24 fanLevel: auto Thermostat mode: heat swing: stopped
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Before HTTPGET to Sensibo., displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug swing Mode :stopped
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug polling children: uvwVRbxg
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug get ACState Success
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Response Status = 200, displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug poll results returned
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Calling refresh() on device: 44adeea5-af8c-42c1-8d17-5ec20fd83dc8
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug getChildDevices(true), children=1
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug refreshDevices() called
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:polling children because 1505418766144 > 1505418511391, displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug polling children because 1505418766144 > 1505418511391
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:pollChild( uvwVRbxg ): 1505418766144 > 1505418511391 ?? w/ current state: [uvwVRbxg:[data:[targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]]], displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug pollChild( uvwVRbxg ): 1505418766144 > 1505418511391 ?? w/ current state: [uvwVRbxg:[data:[targetTemperature:24, coolingSetpoint:24, powerSource:mains, productModel:skyv2, fanLevel:auto, switch:off, thermostatFanMode:auto, Error:Success, temperature:24.3, mode:heat, heatingSetpoint:24, humidity:38.2, temperatureUnit:C, voltage:3000, thermostatMode:off, battery:100, firmwareVersion:IN010050, on:off, swing:stopped]]]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:Last Poll Millis = 1505418466391, displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug Generating AppDebug Event: [name:appdebug, descriptionText:poll child, displayed:false]
e3cb2f92-4a2a-4d04-a605-0ce15d4b5d59 21:52:46: debug poll child
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug Executing ‘poll’ using parent SmartApp
44adeea5-af8c-42c1-8d17-5ec20fd83dc8 21:52:46: debug refresh called
