Funny thing happened to one of my pistons
I have a piston that does the following:
a) if front door is unlocked, and
b) door is closed, then
c) if that remains true for 180 seconds, lock the front door.
The purpose is this: should it happen that one if us unlocks the door but then opts not to open it, OR if the auto-lock routine fails, then the door locks after three minutes.
It worked fine for months. Then just a couple days ago, it started not working. It began ignoring condition (b).
Turns out the piston somehow became corrupted! At first glance it looked OK. After a few minutes I saw it and fixed it easily enough, but somehow the whole conditional statement “shifted right” - became a part of a larger condition. And as there was nothing in the larger condition, it was simply ignoring (a,b) and locking the front door after 180 seconds.
I fixed it so I don’t have anything to show. Just figured I’d mention it, in case others are seeing odd behavior in what seem to be good pistons.
Showing logs for that piston might help us understand what is going on.
I wasn’t logging that piston prior to the issue. I didnt even start logging it… I just saw the issue and fixed it. So it’s working correctly again.
