yes and yes
Holiday Lights: 4th of July / Diwali / Halloween / Christmas - Your Pick
the issue is the edits. you are checking for ALL in one place and ANY in the other for the presence sensors which is breaking the repeat do loop.
the only any i can find is outside the loop does that make a difference?
Edit: sorry just noticed it how do i fix it? as it has true and false in the loop as well
Edit: hopefully may have worked it out just testing
@bangali could you explain the last IF part of the piston to me please, to me it seems contradictory.
So it would only stop if the @pauseHLCRaFp is false ?
no. that if only runs once after 11:00pm when the while loop exits. in normal looping when it changing lights and playing sound that if is not evaluated.
so I shouldnât need my presence in that IF? i cant get it to work correctly yet, do i need to create a variable for the presence so if one of us is there its true and if both are not there it would be false? would that work better?
But when you pause this piston, then resume it again it doesnât run again till the next day? So ie if we left at 7pm then came back at 9 we would want it to continue but it wouldnt?
dont pause the piston. set the flag to true when all away and false when anyone comes back. and go back to using the honj5 piston code version.
@bangali can the new piston be used without sound, ie for those who donât have a sound device. Iâm looking through the posts and whilst the answer may be there, I may just not have seen it yet.
@bangali, super stuff, I didnât think of looking at the piston itself for that. DOH
This is a great piston, many thanks for your work on it and indeed sharing it.
@bangali is there a reason why i get
Piston waited at a semaphore for 4814ms on this piston? and why does it happen, because it happens on some of my other pistons?
its also so simple when you know how
