The timer value shows up in tile 2… it actively counts down, and even changes to “pending” during piston execution. I haven’t set it to be there… I have tried clearing the piston tile to see if some lingering value stuck it there… so far it has proven stealthy and invincible.
This hasn’t stopped the piston from doing what I want it to - this is more of a curious, let’s see if we can figure out what’s going on ‘problem’.
Tile 2 footer should be empty
(PUT YOUR INFO HERE)
The log below includes the clearing of tiles and the setting of Tiles 1, 2, and 3. I see no reference to the timer value in the piston, but it’s staring right at me in Tile 2’s footer.
`(1/16/2018, 9:59:59 AM +147ms
+1ms ╔Received event [Home].time = 1516114800000 with a delay of -853ms
+269ms ║RunTime Analysis CS > 19ms > PS > 54ms > PE > 196ms > CE
+273ms ║Runtime (55945 bytes) successfully initialized in 54ms (v0.2.101.20171227) (270ms)
+274ms ║╔Execution stage started
+290ms ║║Cancelling statement #104’s schedules…
+294ms ║║Executed virtual command clearTile (0ms)
+300ms ║║Cancelling statement #104’s schedules…
+303ms ║║Executed virtual command clearTile (0ms)
+310ms ║║Cancelling statement #104’s schedules…
+313ms ║║Executed virtual command clearTile (1ms)
+319ms ║║Cancelling statement #104’s schedules…
+323ms ║║Executed virtual command clearTile (0ms)
+329ms ║║Cancelling statement #104’s schedules…
+332ms ║║Executed virtual command clearTile (0ms)
+339ms ║║Cancelling statement #104’s schedules…
+342ms ║║Executed virtual command clearTile (1ms)
+348ms ║║Cancelling statement #104’s schedules…
+351ms ║║Executed virtual command clearTile (0ms)
+358ms ║║Cancelling statement #104’s schedules…
+361ms ║║Executed virtual command clearTile (1ms)
+367ms ║║Cancelling statement #104’s schedules…
+371ms ║║Executed virtual command clearTile (0ms)
+377ms ║║Cancelling statement #104’s schedules…
+381ms ║║Executed virtual command clearTile (1ms)
+387ms ║║Cancelling statement #104’s schedules…
+391ms ║║Executed virtual command clearTile (0ms)
+398ms ║║Cancelling statement #104’s schedules…
+401ms ║║Executed virtual command clearTile (1ms)
+407ms ║║Cancelling statement #104’s schedules…
+411ms ║║Executed virtual command clearTile (0ms)
+419ms ║║Cancelling statement #104’s schedules…
+423ms ║║Executed virtual command clearTile (0ms)
+429ms ║║Cancelling statement #104’s schedules…
+432ms ║║Executed virtual command clearTile (0ms)
+438ms ║║Cancelling statement #104’s schedules…
+442ms ║║Executed virtual command clearTile (0ms)
+445ms ║║Cancelling statement #73’s schedules…
+875ms ║║Calculating (string) 31 + (string) ° / >> (string) 31° /
+879ms ║║Calculating (string) 31° / + (string) 31 >> (string) 31° / 31
+883ms ║║Calculating (string) 31° / 31 + (string) ° >> (string) 31° / 31°
+886ms ║║Calculating (string) 31° / 31° + (string) 75% >> (string) 31° / 31° 75%
+889ms ║║Calculating (string) 31° / 31° 75% + (string)
+957ms ║║Calculating (string) :wu-v3- + (string) partlycloudy >> (string) :wu-v3-partlycloudy
+961ms ║║Calculating (string) :wu-v3-partlycloudy + (string) : >> (string)
+964ms ║║Calculating (string) :wu-v3-nt_ + (string) partlycloudy >> (string) :wu-v3-nt_partlycloudy
+967ms ║║Calculating (string) :wu-v3-nt_partlycloudy + (string) : >> (string)
+980ms ║║Calculating (string) Wind: + (string) 0.0 >> (string) Wind: 0.0
+983ms ║║Calculating (string) Wind: 0.0 + (string) >> (string) Wind: 0.0
+987ms ║║Calculating (string) Wind: 0.0 + (string) NNW >> (string) Wind: 0.0 NNW
+990ms ║║Calculating (string) Wind: 0.0 NNW + (string) Gusts: >> (string) Wind: 0.0 NNW Gusts:
+993ms ║║Calculating (string) Wind: 0.0 NNW Gusts: + (string) 0 >> (string) Wind: 0.0 NNW Gusts: 0
+1009ms ║║Executed virtual command setTile (2ms)
+1029ms ║║Calculating (string) 7:24AM + (string) / >> (string) 7:24AM /
+1033ms ║║Calculating (string) 7:24AM / + (string) 5:25PM >> (string) 7:24AM / 5:25PM
+1042ms ║║Calculating (string) Rise + (string) >> (string) Rise
+1046ms ║║Calculating (string) Rise + (string) Set >> (string) Rise Set
+1054ms ║║Executed virtual command setTile (2ms)
+1064ms ║║Cancelling statement #84’s schedules…
+1482ms ║║Executed virtual command setVariable (5ms)
+1516ms ║║Executed virtual command setVariable (4ms)
+1556ms ║║Executed virtual command setVariable (4ms)
+1596ms ║║Executed virtual command setVariable (19ms)
+1603ms ║║Calculating (decimal) 0.0 + (decimal) 3.0 >> (decimal) 3.0
+1634ms ║║Calculating (string)
+ (string) 3 >> (string)
3
+1643ms ║║Calculating (integer) 3 > (integer) 0 >> (boolean) true
+1663ms ║║Calculating (string) / + (string) 5 >> (string) /5
+1672ms ║║Calculating (integer) 5 > (integer) 3 >> (boolean) true
+1683ms ║║Calculating (string) :wu-v3- + (string) clear >> (string) :wu-v3-clear
+1690ms ║║Calculating (string) :wu-v3-clear + (string) : >> (string)
+1695ms ║║Calculating (string) + (string)
3 >> (string)
3
+1701ms ║║Calculating (string)
3 + (string) /5 >> (string)
3/5
+1743ms ║║Calculating (string)
0
+1749ms ║║Calculating (string)
0 + (string) " >> (string)
0"
+1758ms ║║Calculating (decimal) 0.0 > (decimal) 0.0 >> (boolean) false
+1789ms ║║Calculating (string)
0
+1794ms ║║Calculating (string)
0"
+1799ms ║║Calculating (decimal) 0.0 > (decimal) 0.0 >> (boolean) false
+1809ms ║║Calculating (string) 29 + (string) ° >> (string) 29°
+1817ms ║║Calculating (string) 29° + (string) >> (string) 29°
+1823ms ║║Calculating (string) 47 + (string) ° >> (string) 47°
+1831ms ║║Calculating (string) 47° + (string) >> (string) 47°
+1843ms ║║Executed virtual command setTile (2ms))`
