I have four 4 Virtual switch and modes.
- A Mode On (Status : A Mode On)
- B Mode On (Status : A Mode Off, B Mode On)
- A Mode Off (Status : A Mode On, B Mode On) Why??
[Log]
- 오전 12:39:40 +936ms
+1ms ╔Received event [홈 모드].switch = off with a delay of 282ms
+9867ms ║RunTime Analysis CS > 19ms > PS > 9790ms > PE > 58ms > CE
+9867ms ║Piston waited at a semaphore for 9774ms
+9870ms ║Runtime (43052 bytes) successfully initialized in 9790ms (v0.3.104.20180323) (9869ms)
+9871ms ║╔Execution stage started
+9880ms ║║Comparison (enum) off is (string) off = true (0ms)
+9881ms ║║Condition #53 evaluated true (7ms)
+9881ms ║║Condition group #null evaluated true (state did not change) (8ms)
+9888ms ║║Condition #15 evaluated false (5ms)
+9889ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+9891ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+9892ms ║║Condition #27 evaluated false (3ms)
+9893ms ║║Condition group #2 evaluated false (state did not change) (4ms)
+9899ms ║║Condition #28 evaluated false (6ms)
+9900ms ║║Condition group #3 evaluated false (state did not change) (7ms)
+9906ms ║║Condition #52 evaluated false (5ms)
+9907ms ║║Condition group #29 evaluated false (state did not change) (6ms)
+9908ms ║╚Execution stage complete. (37ms)
+9909ms ╚Event processed successfully (9909ms)
- 오전 12:39:42 +71ms
+1ms ╔Received event [홈 모드].switch = on with a delay of 102ms
+83ms ║RunTime Analysis CS > 11ms > PS > 15ms > PE > 57ms > CE
+86ms ║Runtime (42969 bytes) successfully initialized in 15ms (v0.3.104.20180323) (85ms)
+86ms ║╔Execution stage started
+95ms ║║Comparison (enum) off is (string) off = true (1ms)
+96ms ║║Condition #53 evaluated true (7ms)
+97ms ║║Condition group #null evaluated true (state did not change) (7ms)
+103ms ║║Cancelling condition #15’s schedules…
+104ms ║║Condition #15 evaluated false (6ms)
+104ms ║║Cancelling condition #1’s schedules…
+105ms ║║Condition group #1 evaluated false (state changed) (7ms)
+107ms ║║Comparison (enum) on changes_to (string) on = false (0ms)
+108ms ║║Cancelling condition #27’s schedules…
+109ms ║║Condition #27 evaluated false (3ms)
+110ms ║║Cancelling condition #2’s schedules…
+110ms ║║Condition group #2 evaluated false (state changed) (4ms)
+115ms ║║Condition #28 evaluated false (4ms)
+116ms ║║Condition group #3 evaluated false (state did not change) (5ms)
+122ms ║║Condition #52 evaluated false (5ms)
+122ms ║║Condition group #29 evaluated false (state did not change) (6ms)
+124ms ║╚Execution stage complete. (38ms)
+125ms ╚Event processed successfully (125ms)
- 오전 12:39:42 +71ms
- 오전 12:39:40 +707ms
+0ms ╔Received event [외출 모드].switch = on with a delay of 254ms
+85ms ║RunTime Analysis CS > 13ms > PS > 18ms > PE > 54ms > CE
+87ms ║Runtime (42976 bytes) successfully initialized in 18ms (v0.3.104.20180323) (86ms)
+97ms ║║Comparison (enum) off is (string) off = true (1ms)
+99ms ║║Condition #53 evaluated true (9ms)
+100ms ║║Condition group #null evaluated true (state did not change) (10ms)
+105ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+107ms ║║Cancelling condition #15’s schedules…
+108ms ║║Condition #15 evaluated true (5ms)
+109ms ║║Cancelling condition #1’s schedules…
+110ms ║║Condition group #1 evaluated true (state changed) (8ms)
+112ms ║║Cancelling statement #74’s schedules…
+128ms ║║Executed physical command [홈 모드].off() (14ms)
+129ms ║║Executed [홈 모드].off (15ms)
+194ms ║║Skipped execution of physical command [홈-아침 모드].off([]) because it would make no change to the device. (63ms)
+195ms ║║Executed [홈-아침 모드].off (65ms)
+201ms ║║Skipped execution of physical command [홈-취침 모드].off([]) because it would make no change to the device. (4ms)
+202ms ║║Executed [홈-취침 모드].off (5ms)
+204ms ║║Cancelling statement #56’s schedules…
+251ms ║║Executed virtual command setLocationMode (46ms)
+253ms ║╚Execution stage complete. (165ms)
+254ms ╚Event processed successfully (255ms)
- 오전 12:39:37 +947ms
+0ms ╔Received event [홈 모드].switch = on with a delay of 231ms
+88ms ║RunTime Analysis CS > 12ms > PS > 18ms > PE > 59ms > CE
+91ms ║Runtime (42978 bytes) successfully initialized in 18ms (v0.3.104.20180323) (90ms)
+100ms ║║Comparison (enum) off is (string) off = true (1ms)
+101ms ║║Condition #53 evaluated true (7ms)
+102ms ║║Condition group #null evaluated true (state did not change) (8ms)
+109ms ║║Condition #15 evaluated false (5ms)
+110ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+112ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+113ms ║║Cancelling condition #27’s schedules…
+114ms ║║Condition #27 evaluated true (4ms)
+115ms ║║Cancelling condition #2’s schedules…
+116ms ║║Condition group #2 evaluated true (state changed) (5ms)
+117ms ║║Cancelling statement #77’s schedules…
+122ms ║║Skipped execution of physical command [외출 모드].off([]) because it would make no change to the device. (3ms)
+123ms ║║Executed [외출 모드].off (5ms)
+126ms ║║Skipped execution of physical command [홈-아침 모드].off([]) because it would make no change to the device. (2ms)
+127ms ║║Executed [홈-아침 모드].off (3ms)
+131ms ║║Skipped execution of physical command [홈-취침 모드].off([]) because it would make no change to the device. (3ms)
+132ms ║║Executed [홈-취침 모드].off (3ms)
+133ms ║║Cancelling statement #60’s schedules…
+189ms ║║Executed virtual command setLocationMode (53ms)
+191ms ║╚Execution stage complete. (100ms)
+192ms ╚Event processed successfully (193ms)
