As has been noted in multiple posts in this thread, including the one directly above yours, the webCoRE Presence sensor app does not work with Android Oreo and above. It has been effectively abandoned and appears unlikely to be revived.
[Install Instructions] webCoRE Presence Sensor on your Android (beta)
I know this thread is old, but I just noticed today that I can no longer add places in Settings > Places. The âPLUSâ sign tile is no longer there.
Reading through this thread because I accidentally deleted the wrong presence sensor for my wifeâs new phone instead of her old phone. I see a lot of people talking how the presence sensor no longer works on versions of Android newer than Oreo. Iâve been using the presence sensor with no issues on both Oreo and now Android Pie.
The problem stems from the newer battery management in the recent versions of Android. But this can be overridden on an app by app basis.
On my current Pie device, the settings are under settings/battery/app launch. This may vary slightly from device to device, but find your battery settings and there should be some reference to apps.
This gives a list of apps that are managed automatically, and you can switch the toggle over to âmanage manuallyâ which will then allow you to have the app launch on startup or in the background, as well as to keep the app running in the background.
By doing this, the presence sensor updates reliably and I havenât seen any noticeable affect on overall battery life (although Iâm sure there is a minor difference)
Is this still an issue? I tried to remove my phone sensor because it wouldnât update and now I canât get it to show me the setup button again. Do I need to make a new instance again for it show up a second time? The only way it would update was if I forced it to go no present or present, automatic did nothing and I turned off battery optimization and made sure webcore had it âavailableâ to it. Very frustrating!
Beta is long over⌠though technically the app is still the Beta version, just opened up to all.
ok thats what i thought, do you still need a new instance if you want to resetup the presence sensor? I removed it today due to it never updating unless forced and I cant get the setup button back now
You donât need a separate instance for presence, that was solved a long time ago.
The setup button will only appear when accessing the dashboard through the mobile app, if it isnât there try logging out and back in, failing that remove and re-add the app.
Unfortunately the android version of the app has been buggy and is no longer being maintained, seems to work for some but not others.
Yeah I guess it might just be a bug, I did all that and nothing seemed to help but making a new instance worked. If I can get the sensor working I will attempt to integrate it back into the first (main) instance but it really doesnât matter if it doesnât update properly. I am guessing that this is due to the bugs you mentioned. I know the creator got hired by samsung, just surprising they didnât want him to maintain this after hiring.
So yesterday when I left the house both the ST and WC presence sensors updated to âawayâ (the WC version took like 8 mins more than the ST version to update but it did update) but now when I got back this after noon only the ST version went back to HOME the WC still says AWAY. Any ideas why?
Make sure you have all battery saving options disabled for the webcore app. Android will force close the app, preventing it from running it in the background and draining battery, which then causes it not to update itâs location.
Also, if youâre still having issues getting the setup button back, log out, force close the app, clear the cache and data and then log back in.
I assume not much has changed on the WC Presence Sensor but I thought I would give it a go anyway to see what happened as the ST PS is not reliable at all and I have not taken the time to do the Tasker thing or tasker/sharptools (and i had bought ActionTiles before I found the tasker/sharptools option.
For me geo-fencing is still the best option living in a country with limited public wifi so connecting to schools, shopping malls, movie theaters, etc is not always possible. And even where it is available, then we have to make a trip there to do the initial connection on both our phones.
And not a fan of Life360 and all the data it collects and having to pay for another app.
So farâŚmy wifeâs Xiaomi (android 8) seems to be working the best but it has only been running a day and I only had 1 location to test because of where we are at the moment.
For my Huawei running Android 9, I have not had a single update since itâs initial connection yesterday to our current location.
All the battery optimization on both phones has been turned off as much as possible for webCoRE/ST new/ST Classic
Anyone with any recent experience in getting this to work on Android 8 or 9?
With the Huawei you need to disable power genie. It involves hooking it up to a computer and running a few shell commands. Once thatâs disabled then the phone will actually listen to your battery optimization settings. When it runs, even if you disable all optimization, power genie will still force close apps running in the background.
ok thanksâŚI will figure out how to do that. Using WC Presence would be so much better than creating another set of Profiles and tasks in Tasker every time I want to monitor another locationâŚand adding them to everyone elseâs phone.
Came back to work on this again. I deleted webCoRE app from my phone after clearing cache and Data. Did the same thing with Smartthings New and Classic. I reinstalled webCoRE app and it immediately registered and signed in. How is this possible? I should have had to register the browser again to get it working. So just slightly concerned about security and where it is storing this info on my phone.
Also, this means I am unable to re-create the presence sensor in the settings of the app.
Whatâs up?
It is still working very well on my wifeâs Xiaomi after about 10 days but still no luck with getting it to even register a single location on my Huawei Honor phoneâŚand I have disabled PowerGenie also on my phone.
I assume you mean the browser on my phone? Either wayâŚno.
AlsoâŚ1 more question. Since I have ST on my phone and also the webCoRE Smartapp within Smarththings, was it even necessary to install the separate webCoRE app on my phone to do this?
I am getting close to giving up, at least with my phone, and setting up the tasker route instead. The reason I would prefer to use this is because I can manage multiple locations whereas with the ST Presense or Simulated Presence, I can only manage Presence at home.
@MRobiâŚI did manage to disable powerGenie on my Huawei Honor (version 9 android) but that seems to have made no difference. I also turned off battery management for every single gps related app on my phone to try to force it. I ended up deleting both ST apps and webCoRE from my phone, clearing Chrome Browser cache, restarting my phone, etc. I was able to finally re-create the Presence Sensor again but it connected to home and stayed there. I did manage to get it to jump to a new location this morning by manually opening webCoRe but since I have come home it is now still showing me at the old location and killing/opening webcore does not help.
Any last minute thoughts before I officially give up? @Robin ?
Thanks allâŚ
