@jsducote
John, I came across your post today and this is exactly what I am looking for. Any advice or guide on how to do this? I have never used ifttt. Thanks!
V/R,
Frank
@jsducote
V/R,
Frank
Itās fairly straightforward. Log into the API and create a virtual switch under devices. Go to the app: automation > smartapps > webcore > settings > available device and contacts > available devices. Add your new virtual switch under switches. Then go to automation > smartapps > IFTTT and add the virtual switch allowing IFTTT to control it. In the IFTTT app, create a new applet āIf connects to (name of your wifi) then switch on your virtual switchā. Create a second, āif disconnects from (name of your wifi) then switch off your virtual switch.ā
Now you can write almost anything you can imagine in a webcore piston to do something when the virtual switch changes to on or off. Mine unlocks the door from the garage to the kitchen (alarm must be manually disarmed, donāt worry) and turns on the kitchen lights. If itās later than 30 minutes to sunset, other lights are turned on as well.
FYI, the android app presence is broken on Oreo and has been for some time. You can use the app to work on pistons but that is it. Anyway of getting a fix for this?
I would love to see functionality restored to the webCoRE presence sensor. Iām still hanging on to several of my old pistons in the hope that it will happen. If I had the skills, Iād tackle it myself. Unfortunately, I know just enough to be dangerous.
Itās not so much about having the skills⦠more itās about having access to the source code and app stores⦠only @ady624 has those and heās tied up working for ST these days⦠but weāre hoping to get access sometime soon.
Gotcha.
Of course, while it didnāt surprise me at all that ST would hire @ady624 last year, it mystifies me even today that they wouldnāt give him at least a modicum of time to continue webCoRE development, a project to which he contributed so much and which has such potential for the ST community. But those decisions and the reasoning for them are well above my pay grade, and Iām sure it make sense for everyone involved somehow.
Iām digging trying to find out about this new API and canāt find it on the Samsung community forums. Sorry I havenāt been following super closely lately. But I did a quick look-see and canāt find anything. heck I just found out @ady624 went to work for Samsung⦠Itās a good thing because that means everything has been working like clockwork!
@ipaterson has been keeping things running in @ady624ās absence⦠been a few major bugs which he has expertly stamped on.
Here is an overview and in-depth guides for the new API platform and the new Developer Workspace. Itās all still in beta. It should both expand the possibilities of integrating with SmartThings and significantly increase the barriers for projects like webCoRE since all platform costs will be borne by the developer who needs to run services to process everything.
I was super excited to use this as the ST presence just wasnāt firing often enough. Of course, come to find out itās broken in the more recent Android builds. In my case, with Android Pie, I can only get the webcore presence to update once when I open the webcore app. Would love to see the Android app open sourced or at the very least updated.
In my case (and others) it became ābrokenā when Oreo came on line. It stopped working on both mine and my wifeās phones. Didnāt matter, it was drawing 15% battery use on our Galaxy S8, S9 and my daughterās android-based Blackberry. For that reason especially is why I deleted it for all of us.
Hi,
I just installed on my S9. I notice that the APP has to be open in order to trigger something⦠It seems that it does not run on the background (when the app is close⦠). Am i right or did something wrong?
Thanks!
Diego
