No go for me this morning, triggered recovery for mode change via presence.
Is webCoRE slow this morning (16 September, 2019)?
I’ve noticed this problem has returned for me as well. It’s not as bad but it’s definitely back.
Same here. Issues with just about all pistons, even those fired by a virtual switch do not work.
This a repost from many days ago on the ST forum. I too have been having many issues.
I think yesterday and today have been ok but I will scrutinize all my Pistons that have Location daily; these seem to be the ones that were failing or half running.
Over the last 2 weeks all my Good xxx have been either executing, executing only 50% of the piston or not running at all no matter how many times I tell it to execute. Good Bye, I’m Back and Good night seem to be the worse now. All the other pistons work fine but it appears that anything with “Location” mode change is affected.
These pistons were solid for 2 years and now all this random execution; if at all.
Any suggestions would be appreciated.
Logs show partial execution or the snippet below…
I seem to get a lot of this which I’m not sure what it indicates:
18/09/2019, 18:26:06 +879ms
+1ms +Received event [Home V2].time/recovery = 1568856366872 with a delay of 5ms
+2162ms ¦RunTime Analysis CS > 1989ms > PS > 95ms > PE > 80ms > CE
+2166ms ¦Runtime (50094 bytes) successfully initialized in 95ms (v0.3.10f.20190822) (2161ms)
+2167ms ¦+Execution stage started
+2169ms ¦+Execution stage complete. (1ms)
+2179ms +Event processed successfully (2180ms)
18/09/2019, 18:25:55 +131ms
+0ms +Received event [Home V2].time/recovery = 1568856355127 with a delay of 3ms
+156ms ¦RunTime Analysis CS > 31ms > PS > 65ms > PE > 60ms > CE
+159ms ¦Runtime (50091 bytes) successfully initialized in 65ms (v0.3.10f.20190822) (157ms)
+160ms ¦+Execution stage started
+161ms ¦+Execution stage complete. (1ms)
+162ms +Event processed successfully (163ms)
This usually means there was too much congestion in your home network or ST hub… By the time the “recovery” kicked in, I suspect the original conditions were no longer true.
I have very little traffic, most of the 25Meg is free all the time; no kids at home anymore
This is the first time in 4 years I have had this message.
Today I still have pistons failing but it’s always on a piston with Location mode.
It almost looks like it does whatever percentage of work in the piston until it encounters the Location change then it dies and the rest of the commands go unexcuted.
Maybe you could confirm your thoughts by putting the “location mode change action” last and see if everything before it fires. Just a thought
