All of my pistons using “was” trigger are reporting this error.
Example
!Generates this error:
Anyone else seeing this problem. Pretty sure its started after the upgrade this morning.
Example
Can you hunt for that error in the IDE please? Should give you an error line number please
3:47:08 PM: error ║║ Error calling comparison comp_was: java.lang.NullPointerException: Cannot get property ‘id’ on null object @ line 4009.
Thanks
Thank you. Latest version? I will look at it when I get home, too hard to do debugging on a phone
Yes, I updated from Github, this morning and then noticed some of the pistons not firing correctly.
No problem. Whenever you can get to the problem.
Big Fan by the way. Keep up the great work!
I forgot to let you know, I published an update early in the morning - glad it fixed it, thank you.
This error is popping up recently for myself as well.
“An error occurred while executing the event: java.lang.NullPointerException: Cannot get property ‘v’ on null object”
