I take it this is the reason the dashboard is now asking for location permissions? This is in Chrome on W10.
Mobile app for webCoRE
Oi. You lot are getting greedy. lol.
What about us Android peeps with no IOS. (Some might call us sensible).
Plus Iām in the UK so thatās a double handicap.
Yeah thatās a good one. Canāt compete with that⦠Or can I? Iām from Canada after all
No work has been done towards the Android app yet - does Android still work with the Eclipse IDE?
I tested a very simple piston that didnāt trigger when I left a place identified at work for lunch.
if presence_sensor presence changes
then push notification āWebCoRE presence changedā.
Am I missing something? Last executed is never but recent activity for presence_sensor shows a line with āleaving workā and then āplace isā
Presence only reflects the āhomeā place - the one place you set as default - if none is set as home/default, then the first on the list is it. You may want to use
if currentPlace changes away from "Work"
where Work is the name you gave your work place.
Oh ok. Good to know.
I also think I exited inner circle but stayed within the outer one, which would explain the entries in recently.
Beta testing is over, the iOS app can be downloaded from the app store, no need to send PM requests
Beta testing for the iOS app is now open to everyone - send me a private message with the email address, first name and last name. Try to use the email address you have setup as your iTunes account.
PLEASE READ THIS FIRST
BIG WARNING: THERE IS A CURRENT ISSUE WITH SMARTTHINGS THAT CAN CAUSE COMPLETE LOSS OF YOUR WEBCORE INSTANCE - READ BELOW
It appears that deleting the last remaining child device from the ST UI app leads to removing the app as well - without any warning or chance to cancel - this is a āfeatureā of ST and I am working with ST to fix this - it happened to me, added a presence sensor, then removed it from the ST Device List - that lead to the webCoRE app being completely removed, along with all the pistons I had. So I STRONGLY RECOMMEND that until ST fixes this, you install a new blank instance and use that one for the presence sensors. Ye be warned.
READ THIS TOO
WARNING! If you setup a presence sensor device using your main webCoRE instance and then later delete that device from ST, you will loose all your pistons in that instance, as well as the instance itself. Please - PLEASE! - install a blank webCoRE instance, import the DTH from the Device Handlers repository webCoRE - same as you did when you installed the webCoRE SmartApp, then install the iOS app from TestFlight and login with a registration code for the new instance - go to Settings, tap on Setup sensor in the Places tab, pick a name for the sensor (you can safely change this later from ST) and hit Save - that will create a presence sensor in your ST app, provided you correctly created and published the DTH - you do not have to create any virtual devices, just make sure you publish the DTH, webCoRE will create the devices for you.
Thank you
Lol. Sounds like a new policy is coming from cosmoās Fingers soon.
Emails only in PMs
Lol
Non-Campbellās soup post
This afternoon my presence did not update (it did this morning), when I went into the webCoRE app it asked for location access again⦠I thought that was odd, but after I granted it I āarrivedā.
Just thought Iād share.
Just downloaded the app from TestFlight.
Created a new webCoRe instance.
Added the webcore-presence-sensor dth on ST.
Published the DTH.
Logged in to the app using the registration key from the new webcore instance. Approved all messages about location.
Went to Settings, under āPlacesā tapped on the + sign, map appears (showing my location), i gave it a name and tapped on āSaveā.
āSetup sensorā button appears. Tapped on it and gave it a name and tapped on āSaveā. (i still see āSetup sensorā rather than the name i gave it.)
Checked in ST and device is not there.
Am i missing anything? Using iPhone 7 Plus on iOS11.
Did you pressed apply after saving? Something similar happened to me and IIRC, it was because I forgot to apply. Might worth a try.
I had this problem too. I was able to setup the sensor correctly on my phone and it showed up.
When I went to my daughters phone, she had to be logged into my Apple ID for TestFlight to see the webcore app. Once she ddownloaded the webcore app and it was on her phone, she needed to re-login to her Apple ID. Then open the webcore app and setup the sensor portion for her phone. It then showed in smartthings. The need to go into webcore settings and include that senses or for presence in order for webcore to use it.
Hope that makes sense
Tom
Confirm that the DTH is published. Killed the app, even tried removing it and reinstalling it with the same result.
Also can confirm that i did hit āApplyā after creating it. The device is still not showing up in ST.
Some screenshots.
make sure your smartapp (in IDE) is up to date and published.
Kill WC iOS app, re open, create new instance.
Then try again. Just walked a buddy through this today. it was his smartapp out of date
