My instance will no longer open
I tried to load a meg piston and I can no longer open the instance that I had it in. Any suggestions on how to fix this?
NM Got it back…man that was close
FYI… clicking that delete button in the browser will not harm your pistons, it just clears the login link between the web dashboard and the ST instance.
After deleting it can be easily added again using a new ‘register a browser’ code.
Well the way I fixed it was went into the instance in ST on the phone. Cleared cache and somehow the piston ended up in pause and then I deleted it. I guess it was just way to big with all the other pistons I had.
