Need help with OAuth
I was forced to do a Factory Reset on my SmartThings hub after i had successfully installed and started using WebCoRE. After working with ST staff I have successfully reinstalled everything and it’s up and working excpect WebCoRE.
I followed the installation as written including OAuth. WebCoRE is up and functional but when I attempt to create a piston using the defaults the screen spins and returns to the piston create screen.
From my research I believe my issue is due to my new installation having a new OAuth value that is different from my previous install. How do I update with WebCoRE my new OAuth?
archived #2
Duplicate of Fix Broken OAuth
