Netatmo Rain Gauge - Fuel Stream Error
Good Morning,
About two weeks ago, this fuel stream ceased working displaying the attached result.
Attached is the piston.
Try changing your rain variable to integer instead of dynamic.
To add to this, you should always define what the variable type will be if you know it will be static
Trying that now… Just waiting for rain. I will keep you posted.
Should have been here in Kansas. We got 5-10 inches in varying places
So it rained last night 0.4 inches per ST!
Still the same result.
47 PM|689x196
It’s likely your data tables have strings and integers mixed up now… you might need to start a new dataset… rain2?
Unfortunately we don’t have delete, rename, merge, edit functions yet so you’ll be stuck with the old ‘rain’ on the list for now.
Worked! Thank you so much.
Wait! This might be an integer issue. We had 1.25 in. Of rain on Saturday. The fuel stream displayed 1. It seems to only reflect as a whole number.
Maybe try decimal
I will give that a try. That may fix another piston I have that takes rain into account.
