On event can't remove button device
If I create something like this:
On Events from
    Button Controller gets pushed
Do
    Log something to console
After, I’m not able adjust “Button Controller” to something else. If I click the piston line, nothing happens. This seems to only happen with buttons (so far); Switches and bulbs seem fine. I’ve tried two different browsers. Does this happen to you?
My work around was to create a second “On events from”, drag the old device into it, and delete the second “On events” statement.
Try with staging.webcore.co to see it it works there
