I added a few contact sensors for my windows and doors and I wanted to make a few tiles in the dashboard for them. However, when I try to add them to the piston, the physical device doesn’t show up in the drop down list. The only things that show up are 4 light bulbs. I’ve updated my webcore to the latest version but to no avail. Any idea how to go about this?
Physical Devices Not Showing Up
Baz2473
Don’t forget to allow WebCoRE access to them by following the below instructions.
Open your smarthings app on your mobile device,
Click on the “Automation” tab at the bottom.
Click on the “Smart Apps” Tab at the top.
Click on your “WebCoRE” instance that you will be using them in
Click on “Settings”
Click on “Available Devices And Contacts”
Click on “Available Devices”
Click on “Which Actuators”
SELECT EVERY DEVICE YOU WANT WEBCORE TO BE ABLE TO USE
Then Click “DONE” & “DONE” & “BACK” & “DONE” & “DONE”
