13/10/2017, 07:54:30 +234ms +3ms ╔Received event [Home].test = 1507877670227 with a delay of 6ms +146ms ║RunTime Analysis CS > 20ms > PS > 49ms > PE > 75ms > CE +157ms ║Runtime (50882 bytes) successfully initialized in 49ms (v0.2.0fa.20171011) (153ms) +160ms ║╔Execution stage started +168ms ║║Comparison (enum) on is (string) on = true (1ms) +169ms ║║Condition #42 evaluated true (6ms) +170ms ║║Condition group #null evaluated true (state did not change) (7ms) +174ms ║║Comparison (string) :00a05f15f14bac7fcf8b8b721fbdb88b: is (string) :7d38143ce28f077111de1773d2583cdb: = false (1ms) +175ms ║║Condition #41 evaluated false (3ms) +176ms ║║Condition group #2 evaluated false (state did not change) (4ms) +185ms ║║Condition #53 evaluated false (7ms) +186ms ║║Condition group #5 evaluated false (state did not change) (7ms) +195ms ║║Condition #19 evaluated false (7ms) +196ms ║║Condition group #14 evaluated false (state did not change) (8ms) +204ms ║║Condition #46 evaluated false (4ms) +204ms ║║Condition group #45 evaluated false (state did not change) (5ms) +239ms ║║Comparison (enum) present is (string) present = true (1ms) +240ms ║║Condition #49 evaluated true (35ms) +246ms ║║Comparison (time) 28470475 is_between (time) 30600000 .. (time) 32400000 = false (4ms) +248ms ║║Condition #50 evaluated false (6ms) +248ms ║║Condition group #48 evaluated false (state did not change) (43ms) +249ms ║║Condition group #44 evaluated false (state did not change) (51ms) +250ms ║║Cancelling statement #22's schedules... +251ms ║║Condition group #22 evaluated false (state did not change) (53ms) +252ms ║║Cancelling statement #23's schedules... +279ms ║║Executed virtual command setLocationMode (22ms) +282ms ║╚Execution stage complete. (124ms) +292ms ╚Event processed successfully (292ms) 13/10/2017, 07:52:53 +41ms +265ms ║An error has occurred while subscribing: groovy.lang.MissingPropertyException: No such property: r for class: java.lang.Boolean
bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Condition group #14 evaluated false (state did not change) (8ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Condition group #2 evaluated false (state did not change) (4ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Condition #19 evaluated false (7ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Comparison (string) :00a05f15f14bac7fcf8b8b721fbdb88b: is (string) :7d38143ce28f077111de1773d2583cdb: = false (1ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Condition #53 evaluated false (7ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Condition #41 evaluated false (3ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Condition group #null evaluated true (state did not change) (7ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║║ Comparison (enum) on is (string) on = true (1ms) bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: trace ║╚ Execution stage started bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: debug ║ RunTime Analysis CS > 20ms > PS > 49ms > PE > 75ms > CE bd80be79-4ded-40c1-a56e-1a1e757765a8 07:54:30: info ╚ Received event [Home].test = 1507877670227 with a delay of 6ms bd80be79-4ded-40c1-a56e-1a1e757765a8 07:52:53: error ║ An error has occurred while subscribing: groovy.lang.MissingPropertyException: No such property: r for class: java.lang.Boolean @ line 4488
I wonder if you fixed it in the update?
Sorry I did know how to get the logging on the IDE but wasn’t sure, didn’t want to paste it if it was wrong. But after @c1arkbar post this should be everything you need.
line 4488
