I have a piston that last ran a year ago. I can’t open it in WebCore, pause it in WebCore or ST API, or delete it through the ST API. If I try to duplicate the piston in WebCore, I get a new, blank piston. Although I have auto backups turned on, I don’t have the backup code and I can’t see the backup code in the ST API because no info pops up when I hover over it or click on it.
I have tried to clean up and rebuild data cache, but there was no change.
I’ve also tried to log in to both WebCore and ST API in an incognito window, but no change.
I should be able to open or pause the piston through the dashboard, and I should be able to pause or delete it through the ST API.
When I try to open it in the dashboard, I either get the spinning circle, or it says something went wrong.
When I try to delete it via ST API, it says, “There was an error uninstalling your SmartApp.”
When I try to open it, I see the following error in the ST Live Log:
error groovy.json.JsonException: expecting current character to be ‘d’ with an int value of 100
The current character read is ‘d’ with an int value of 100
line number 1
index number 336
{“t”:1600249650103,“points”:{“t:37”:{“o”:360,“d”:19,“v”:0},“s:36”:{“o”:358,“d”:21,“v”:true},“s:10”:{“o”:155,“d”:225,“v”:true},“t:39”:{“o”:382,“d”:17,“v”:0},“s:38”:{“o”:381,“d”:19,“v”:true},“c:41”:{“o”:401,“d”:4,“v”:true},“c:40”:{“o”:401,“d”:5,“v”:true},“c:49”:{“o”:409,“d”:4,“v”:false},“c:48”:{“o”:…[TRUNCATED]
Can’t open the piston to take a snapshot.
Can’t open the piston to capture the log.
Thanks in advance!
