I was trying to help someone else with location mode changes and threw a sample piston together. In the process I found an unexpected loop condition?
Here is the piston I was trying:
For some reason the wait section starts loping and reruns every 25+ seconds? It also never recognizes the change in location mode from home to test.
Here are the logs:
|9/7/2018, 3:41:07 AM +881ms|
|+0ms|╔Received event [Home].execute = recovery with a delay of 122ms|
|+117ms|║RunTime Analysis CS > 30ms > PS > 61ms > PE > 26ms > CE|
|+119ms|║Runtime (41830 bytes) successfully initialized in 61ms (v0.3.108.20180906) (118ms)|
|+121ms|║╔Execution stage started|
|+127ms|║║Cancelling statement #1’s schedules…|
|+155ms|║║Executed virtual command setLocationMode (25ms)|
|+163ms|║║Comparison (string) :ca74bc6d2a57b658492ce9d87c1e8684: is (string) :ca74bc6d2a57b658492ce9d87c1e8684: = true (2ms)|
|+165ms|║║Cancelling condition #4’s schedules…|
|+166ms|║║Condition #4 evaluated true (7ms)|
|+167ms|║║Cancelling condition #3’s schedules…|
|+169ms|║║Condition group #3 evaluated true (state changed) (10ms)|
|+171ms|║║Cancelling statement #5’s schedules…|
|+176ms|║║Executed virtual command wait (0ms)|
|+177ms|║║Requesting a wake up for Fri, Sep 7 2018 @ 3:41:13 AM CDT (in 5.0s)|
|+183ms|║╚Execution stage complete. (63ms)|
|+185ms|║Setting up scheduled job for Fri, Sep 7 2018 @ 3:41:13 AM CDT (in 4.994s)|
|+201ms|╚Event processed successfully (201ms)|
|9/7/2018, 3:41:07 AM +872ms|
|+0ms|╔Received event [Home].mode = Home with a delay of 95ms|
|+103ms|║RunTime Analysis CS > 28ms > PS > 50ms > PE > 25ms > CE|
|+105ms|║Runtime (41822 bytes) successfully initialized in 50ms (v0.3.108.20180906) (104ms)|
|+106ms|║╔Execution stage started|
|+112ms|║║Cancelling statement #1’s schedules…|
|+134ms|║║Executed virtual command setLocationMode (18ms)|
|+142ms|║║Comparison (string) :ca74bc6d2a57b658492ce9d87c1e8684: is (string) :ca74bc6d2a57b658492ce9d87c1e8684: = true (2ms)|
|+144ms|║║Cancelling condition #4’s schedules…|
|+146ms|║║Condition #4 evaluated true (8ms)|
|+147ms|║║Cancelling condition #3’s schedules…|
|+148ms|║║Condition group #3 evaluated true (state changed) (11ms)|
|+151ms|║║Cancelling statement #5’s schedules…|
|+156ms|║║Executed virtual command wait (1ms)|
|+158ms|║║Requesting a wake up for Fri, Sep 7 2018 @ 3:41:13 AM CDT (in 5.0s)|
|+163ms|║╚Execution stage complete. (57ms)|
|+165ms|║Setting up scheduled job for Fri, Sep 7 2018 @ 3:41:13 AM CDT (in 4.995s)|
|+177ms|╚Event processed successfully (177ms)|
|9/7/2018, 3:41:07 AM +624ms|
|+1ms|╔Received event [Home].mode = Test with a delay of 89ms|
|+109ms|║RunTime Analysis CS > 28ms > PS > 59ms > PE > 21ms > CE|
|+111ms|║Runtime (41820 bytes) successfully initialized in 59ms (v0.3.108.20180906) (110ms)|
|+113ms|║╔Execution stage started|
|+119ms|║║Cancelling statement #1’s schedules…|
|+164ms|║║Executed virtual command setLocationMode (42ms)|
|+172ms|║║Comparison (string) :98b88b0ac53cf63986ce6c6d405dade0: is (string) :ca74bc6d2a57b658492ce9d87c1e8684: = false (2ms)|
|+174ms|║║Cancelling condition #4’s schedules…|
|+175ms|║║Condition #4 evaluated false (8ms)|
|+177ms|║║Cancelling condition #3’s schedules…|
|+178ms|║║Condition group #3 evaluated false (state changed) (10ms)|
|+181ms|║╚Execution stage complete. (68ms)|
|+182ms|╚Event processed successfully (182ms)|
|9/7/2018, 3:41:06 AM +803ms|
|+1ms|╔Received event [Home].time = 1536309623484 with a delay of 43319ms|
|+563ms|║RunTime Analysis CS > 213ms > PS > 309ms > PE > 40ms > CE|
|+567ms|║Runtime (41835 bytes) successfully initialized in 309ms (v0.3.108.20180906) (565ms)|
|+569ms|║╔Execution stage started|
|+748ms|║║Executed virtual command setLocationMode (153ms)|
|+759ms|║║Calculating (string) we are in + (string) Home >> (string) we are in Home|
|+765ms|║║ we are in Home|
|+766ms|║║Executed virtual command log (1ms)|
|+769ms|║╚Execution stage complete. (201ms)|
|+770ms|╚Event processed successfully (770ms)|
|9/7/2018, 3:40:08 AM +330ms|
|+1ms|╔Received event [Home].mode = Home with a delay of 79ms|
|+10099ms|║RunTime Analysis CS > 14ms > PS > 10063ms > PE > 21ms > CE|
|+10100ms|║Piston waited at a semaphore for 10021ms|
|+10102ms|║Runtime (41902 bytes) successfully initialized in 10063ms (v0.3.108.20180906) (10100ms)|
|+10103ms|║╔Execution stage started|
|+10109ms|║║Cancelling statement #1’s schedules…|
|+10129ms|║║Executed virtual command setLocationMode (15ms)|
|+10137ms|║║Comparison (string) :ca74bc6d2a57b658492ce9d87c1e8684: is (string) :ca74bc6d2a57b658492ce9d87c1e8684: = true (3ms)|
|+10139ms|║║Cancelling condition #4’s schedules…|
|+10140ms|║║Condition #4 evaluated true (8ms)|
|+10142ms|║║Cancelling condition #3’s schedules…|
|+10143ms|║║Condition group #3 evaluated true (state changed) (11ms)|
|+10146ms|║║Cancelling statement #5’s schedules…|
|+10151ms|║║Executed virtual command wait (0ms)|
|+10153ms|║║Requesting a wake up for Fri, Sep 7 2018 @ 3:40:23 AM CDT (in 5.0s)|
|+10159ms|║╚Execution stage complete. (55ms)|
|+10161ms|║Setting up scheduled job for Fri, Sep 7 2018 @ 3:40:23 AM CDT (in 4.994s)|
|+10274ms|╚Event processed successfully (10274ms)|
|9/7/2018, 3:40:08 AM +127ms|
|+1ms|╔Received event [Home].mode = Test with a delay of 82ms|
|+88ms|║RunTime Analysis CS > 24ms > PS > 39ms > PE > 25ms > CE|
|+91ms|║Runtime (41816 bytes) successfully initialized in 39ms (v0.3.108.20180906) (89ms)|
|+92ms|║╔Execution stage started|
|+99ms|║║Cancelling statement #1’s schedules…|
|+137ms|║║Executed virtual command setLocationMode (33ms)|
|+146ms|║║Comparison (string) :98b88b0ac53cf63986ce6c6d405dade0: is (string) :ca74bc6d2a57b658492ce9d87c1e8684: = false (3ms)|
|+148ms|║║Cancelling condition #4’s schedules…|
|+149ms|║║Condition #4 evaluated false (8ms)|
|+151ms|║║Cancelling condition #3’s schedules…|
|+153ms|║║Condition group #3 evaluated false (state changed) (12ms)|
|+155ms|║╚Execution stage complete. (63ms)|
|+157ms|╚Event processed successfully (157ms)|
|9/7/2018, 3:40:07 AM +558ms|
|+0ms|╔Received event [Home].time = 1536309590835 with a delay of 16722ms|
|+376ms|║RunTime Analysis CS > 126ms > PS > 217ms > PE > 34ms > CE|
|+380ms|║Runtime (41832 bytes) successfully initialized in 217ms (v0.3.108.20180906) (379ms)|
|+382ms|║╔Execution stage started|
|+502ms|║║Executed virtual command setLocationMode (96ms)|
|+515ms|║║Calculating (string) we are in + (string) Home >> (string) we are in Home|
|+521ms|║║ we are in Home|
|+523ms|║║Executed virtual command log (3ms)|
|+528ms|║╚Execution stage complete. (147ms)|
|+530ms|╚Event processed successfully (530ms)|
|9/7/2018, 3:39:45 AM +680ms|
|+0ms|╔Received event [Home].mode = Home with a delay of 94ms|
|+101ms|║RunTime Analysis CS > 26ms > PS > 52ms > PE > 24ms > CE|
|+104ms|║Runtime (41822 bytes) successfully initialized in 52ms (v0.3.108.20180906) (103ms)|
|+105ms|║╔Execution stage started|
|+111ms|║║Cancelling statement #1’s schedules…|
|+131ms|║║Executed virtual command setLocationMode (17ms)|
|+140ms|║║Comparison (string) :ca74bc6d2a57b658492ce9d87c1e8684: is (string) :ca74bc6d2a57b658492ce9d87c1e8684: = true (1ms)|
|+142ms|║║Cancelling condition #4’s schedules…|
|+143ms|║║Condition #4 evaluated true (8ms)|
|+144ms|║║Cancelling condition #3’s schedules…|
|+145ms|║║Condition group #3 evaluated true (state changed) (11ms)|
|+148ms|║║Cancelling statement #5’s schedules…|
|+153ms|║║Executed virtual command wait (0ms)|
|+154ms|║║Requesting a wake up for Fri, Sep 7 2018 @ 3:39:50 AM CDT (in 5.0s)|
|+160ms|║╚Execution stage complete. (55ms)|
|+162ms|║Setting up scheduled job for Fri, Sep 7 2018 @ 3:39:50 AM CDT (in 4.994s)|
|+175ms|╚Event processed successfully (175ms)|
|9/7/2018, 3:39:44 AM +737ms|
|+1ms|╔Received event [Home].time = 1536309568896 with a delay of 15841ms|
|+435ms|║RunTime Analysis CS > 202ms > PS > 208ms > PE > 24ms > CE|
|+437ms|║Runtime (41832 bytes) successfully initialized in 208ms (v0.3.108.20180906) (435ms)|
|+439ms|║╔Execution stage started|
|+666ms|║║Executed virtual command setLocationMode (210ms)|
|+676ms|║║Calculating (string) we are in + (string) Home >> (string) we are in Home|
|+682ms|║║ we are in Home|
|+683ms|║║Executed virtual command log (2ms)|
|+686ms|║╚Execution stage complete. (248ms)|
|+688ms|╚Event processed successfully (687ms)|
