Some more reports here:
And numerous reports of General ST instability going on:
Yes. ST placed a rate limit on webCoRE because some pistons started executing like crazy because of the DST. I donāt know what the rate limit is, looks like 0, as none of my pistons execute at all. But will try to get this fixed. Not sure how quick I can get someone to react, itās still early morning on the west coast.
Hey, at least the time change worked fine this year, unlike last year, ST got something right
To the question posted a bit above, do I recall that you are working with ST to get this app officially supported?
Thanks Adrian for all you do
Rick
Quick dirty fix. Please update to 0fc to get it back working. Thank you and sorry for the trouble.
Iām new to webCoRE and it looks like I picked a bad day to start transitioning from basic ST automations. Can someone provide a little more details behind how to āupdate 0fcā? I havenāt a clue what that is. Otherwise, Iāll wait a couple days to implement.
So hereās what I think happened. I am using UTC time throughout webCoRE (a common approach in the telecom industry) to avoid any DST issues. So when youāre piston runs at 9pm on Saturday before the DST and it is scheduled to run at 9pm on Sunday after the DST, I will work in UTC times, meaning the delta time between the two time points will be 25 hours. So I do a runIn in 25 hours (the request is already DST adjusted) - SmartThings was not āadjustingā it to DST before, it seems that they added a fix this year that will adjust that runIn time with DST. This is most likely because some programmers and most DYI users would not be aware of what DST entails and would just send the unadjusted runIn time. Which now may explain why some apps worked fine this time around. But it seems that broke webCoRE
Iāll see with ST what exactly happens and Iāll do some experiments simulating DST to see what exactly happens. Until then, ST will most likely remove the rate limit at some point - it affects certain versions of webCoRE - when they start their working schedule - itās Sunday early morning there, so I would not expect anyone to be available to really dig in and fix the issue. This seems to have been an emergency fix last night and ST was kind enough to let me know - I did have a message explaining the problem and the fix.
I just finished updating and everything is working better. BUT. I have logging on for one of my pistons and it looks like itās displaying 1 hour behind. I.E. If I want it to sent an email at 4am it is showing the wake up time for 3am. Anyone else seeing this?
āStarting piston⦠(v0.2.0fc.20171105)
+671ms āāSubscribing to devicesā¦
+927ms āāFinished subscribing (261ms)
+969ms āComparison (time) 33318752 happens_daily_at (time) 0 = false (3ms)
+984ms āCancelling statement #12ās schedulesā¦
+993ms āRequesting time schedule wake up at Sun, Nov 5 2017 @ 11:00:00 PM EST
+1029ms āComparison (time) 33318816 happens_daily_at (time) 14400000 = false (1ms)
+1032ms āCancelling condition #4ās schedulesā¦
+1034ms āCancelling statement #4ās schedulesā¦
+1036ms āRequesting time schedule wake up at Mon, Nov 6 2017 @ 3:00:00 AM EST
+1038ms āCancelling condition #1ās schedulesā¦
+1080ms āSetting up scheduled job for Sun, Nov 5 2017 @ 11:00:00 PM EST (in 49481.132s), with 1 more job pending
+1105ms āPiston successfully started (1102ms)
My next scheduled piston is for 25 minutes to sunset and it is scheduled to run at 5:07:00 PM which is correct. However, Iām in AZ and our time doesnāt change for DST so that may be why my piston times are correct.
Thanks Boxfan⦠I have a piston that runs 1 hours before sunset and itās next scheduled time is also correct. (4:06pm and sunset is 5:05pm) . It looks like itās a issue with my āhappens daily atā .
I checked my morning routine and itās Next scheduled is 5am where the piston is set to 6am.
On the road here. Just updated on my phone. Some 1/2 hr later i got a email i should have seen some 6 hrs ago. Not able to debug here. CET
