Relax. It will, tomorrow, at least. Until then use interface from SmartThings.
Pistons have stopped working! [daylight savings time issues]
#usertips
Think about the pistons you use for SHM stuff.
I have disabeled some security stuff until fix is in place.
Cameras and some other stuff will trigger ST alarm if they dont disarm from WebCoRE.
Times seem to be correct
UPDATE:
Spoke too soon ⌠time($now) is off by an hour for me ⌠1 hour behind ⌠but at least the piston works.
Wonât disable all pistons or clear cache and rebuild does it for every pistons?
Edit: nope, it doesnât do it lol
things are guaranteed to work, as the rate limit wonât affect the new version - that does not mean it works fine and ST wonât block it again - I am having high hopes that this fixed it, there is a slight change things will be off tomorrow(??!) and there is no easy way for me to simulate how things would work tomorrow
Tried that.
This still does not work
Received event [MotSe Kitchen].motion = active with a delay of 200ms
+547ms âRunTime Analysis CS > 53ms > PS > 394ms > PE > 101ms > CE
+557ms âPiston waited at a semaphore for 295ms
+559ms âRuntime (45196 bytes) successfully initialized in 394ms (v0.2.0fd.20171105) (558ms)
+560ms ââExecution stage started
+573ms ââComparison (enum) active is (string) active = true (1ms)
+574ms ââCondition #37 evaluated true (8ms)
+575ms ââCondition group #36 evaluated true (state did not change) (10ms)
+577ms ââCancelling statement #2âs schedulesâŚ
+586ms ââExecuted virtual command [Hue color lamp 2 stue, Hue color lampe 1 stue, Portable, Strip].setVariable (2ms)
+587ms ââSkipping task 3 because of mode restrictions
+591ms ââExecuted virtual command [Hue color lamp 2 stue, Hue color lampe 1 stue, Portable, Strip].wait (2ms)
+592ms ââRequesting a wake up for Mon, Nov 6 2017 @ 1:05:48 AM CET (in 1800.0s)
+612ms ââComparison (enum) inactive is (string) active = false (2ms)
+614ms ââComparison (enum) active is (string) active = true (1ms)
+616ms ââCondition #12 evaluated true (18ms)
+616ms ââCondition group #7 evaluated true (state did not change) (19ms)
+618ms ââCancelling statement #8âs schedulesâŚ
+627ms ââExecuted virtual command [Dimmer eat, Dimmer kitchen].setVariable (2ms)
+628ms ââSkipping task 9 because of mode restrictions
+631ms ââExecuted virtual command [Dimmer eat, Dimmer kitchen].wait (1ms)
+633ms ââRequesting a wake up for Mon, Nov 6 2017 @ 12:45:48 AM CET (in 600.0s)
+647ms ââComparison (enum) inactive is (string) active = false (1ms)
+648ms ââCondition #18 evaluated false (11ms)
+649ms ââCondition group #13 evaluated false (state did not change) (12ms)
+653ms ââExecution stage complete. (93ms)
+655ms âSetting up scheduled job for Mon, Nov 6 2017 @ 12:45:48 AM CET (in 599.98s), with 1 more job pending
+673ms âEvent processed successfully (673ms)
6.11.2017, 00:35:47 +498ms
+1ms âReceived event [MotSe Eat].motion = active with a delay of 171ms
+191ms âRunTime Analysis CS > 25ms > PS > 89ms > PE > 77ms > CE
+202ms âRuntime (45129 bytes) successfully initialized in 89ms (v0.2.0fd.20171105) (201ms)
+203ms ââExecution stage started
+217ms ââComparison (enum) active is (string) active = true (1ms)
+218ms ââCondition #37 evaluated true (9ms)
+219ms ââCondition group #36 evaluated true (state did not change) (10ms)
+221ms ââCancelling statement #2âs schedulesâŚ
+231ms ââExecuted virtual command [Hue color lamp 2 stue, Hue color lampe 1 stue, Portable, Strip].setVariable (3ms)
+232ms ââSkipping task 3 because of mode restrictions
+235ms ââExecuted virtual command [Hue color lamp 2 stue, Hue color lampe 1 stue, Portable, Strip].wait (1ms)
+236ms ââRequesting a wake up for Mon, Nov 6 2017 @ 1:05:47 AM CET (in 1800.0s)
+256ms ââComparison (enum) inactive is (string) active = false (1ms)
+258ms ââComparison (enum) active is (string) active = true (1ms)
+259ms ââCancelling condition #12âs schedulesâŚ
+260ms ââCondition #12 evaluated true (20ms)
+261ms ââCancelling condition #7âs schedulesâŚ
+262ms ââCondition group #7 evaluated true (state changed) (22ms)
+264ms ââCancelling statement #8âs schedulesâŚ
+272ms ââExecuted virtual command [Dimmer eat, Dimmer kitchen].setVariable (2ms)
+273ms ââSkipping task 9 because of mode restrictions
+276ms ââExecuted virtual command [Dimmer eat, Dimmer kitchen].wait (1ms)
+277ms ââRequesting a wake up for Mon, Nov 6 2017 @ 12:45:47 AM CET (in 600.0s)
+290ms ââComparison (enum) inactive is (string) active = false (2ms)
+291ms ââCondition #18 evaluated false (10ms)
+292ms ââCondition group #13 evaluated false (state did not change) (11ms)
+296ms ââExecution stage complete. (92ms)
+297ms âSetting up scheduled job for Mon, Nov 6 2017 @ 12:45:47 AM CET (in 599.981s), with 1 more job pending
+315ms âEvent processed successfully (315ms)
