I posted about this issue 10 days ago on the ST forums HERE so re-posting on these forums in effort to get this resolved as it’s causing issues with a lot of my pistons and still an outstanding issue
Original post:
I am having issues since the latest update with Pistons executing and ignoring restrictions. I’ve isolated the problem to pistons that have a duration trigger (IE: If lights are off for 5 minutes then…) kind of triggers. It’s currently 14:26 and the restrictions on my piston are for the Piston to only fire between 21:00 and 05:00 but it keeps executing.
At 14:17:48, a scheduled job is setup to run but shouldn’t be due to the time restrictions. Once that time hits, the piston runs and the Goodbye! routine is run
+600ms ║Setting up scheduled job for Wed, Aug 16 2017 @ 2:22:49 PM EDT (in 299.939s)
I’ve had this piston running this way without modification for over a month and this issue just started after upgrading webCoRE the other day to the latest version
Here are the logs and the piston itself:
16/08/2017, 14:22:48 +258ms
+1ms ╔Received event [Homelands].time = 1502907769040 with a delay of -783ms
+560ms ║RunTime Analysis CS > 145ms > PS > 98ms > PE > 317ms > CE
+579ms ║Runtime (39477 bytes) successfully initialized in 98ms (v0.2.0e5.20170812) (577ms)
+582ms ║╔Execution stage started
+614ms ║║Cancelling condition #11’s schedules…
+620ms ║║Condition #11 evaluated true (8ms)
+692ms ║║Comparison (enum) off is (string) off = true (5ms)
+701ms ║║Comparison (enum) off is (string) off = true (6ms)
+710ms ║║Comparison (enum) off is (string) off = true (5ms)
+717ms ║║Comparison (enum) off is (string) off = true (4ms)
+722ms ║║Comparison (enum) off is (string) off = true (3ms)
+728ms ║║Condition #15 evaluated true (106ms)
+730ms ║║Cancelling condition #4’s schedules…
+732ms ║║Condition group #4 evaluated true (state changed) (121ms)
+739ms ║║Cancelling statement #12’s schedules…
+794ms ║║Executed virtual command sendPushNotification (42ms)
+10236ms ║║Executed virtual command executeRoutine (9433ms)
+10241ms ║╚Execution stage complete. (9659ms)
+10250ms ╚Event processed successfully (10250ms)
16/08/2017, 14:17:48 +502ms
+1ms ╔Received event [Theatre Mood Light].switch = off with a delay of 259ms
+403ms ║RunTime Analysis CS > 88ms > PS > 78ms > PE > 237ms > CE
+413ms ║Runtime (39476 bytes) successfully initialized in 78ms (v0.2.0e5.20170812) (410ms)
+414ms ║╔Execution stage started
+431ms ║║Comparison (string) :e329209b02524180269aeacb19563898: is_any_of (string) :beaf06d1244cff657bfc5a964ce25c62:,:e329209b02524180269aeacb19563898: = true (4ms)
+433ms ║║Condition #1 evaluated true (11ms)
+450ms ║║Comparison (time) 51468937 is_between (time) 75600000 … (time) 18060000 = false (10ms)
+452ms ║║Condition #2 evaluated false (18ms)
+454ms ║║Condition group #null evaluated false (state did not change) (33ms)
+455ms ║║Piston execution aborted due to restrictions in effect
+473ms ║║Comparison (time) 51468962 is_between (time) 75600000 … (time) 18000000 = false (10ms)
+516ms ║║Comparison (enum) off stays (string) off = true (4ms)
+520ms ║║Comparison (enum) off stays (string) off = true (3ms)
+525ms ║║Comparison (enum) off stays (string) off = true (3ms)
+529ms ║║Comparison (enum) off stays (string) off = true (2ms)
+533ms ║║Comparison (enum) off stays (string) off = true (3ms)
+538ms ║║Adding a timed trigger schedule for condition 11
+570ms ║║Comparison (enum) off is (string) off = true (3ms)
+573ms ║║Comparison (enum) off is (string) off = true (2ms)
+577ms ║║Comparison (enum) off is (string) off = true (3ms)
+581ms ║║Comparison (enum) off is (string) off = true (3ms)
+585ms ║║Comparison (enum) off is (string) off = true (2ms)
+588ms ║║Cancelling condition #15’s schedules…
+597ms ║╚Execution stage complete. (184ms)
+619ms ╚Event processed successfully (620ms)
16/08/2017, 14:17:41 +176ms
+2ms ╔Received event [Theatre Mood Light].switch = on with a delay of 188ms
+699ms ║RunTime Analysis CS > 140ms > PS > 323ms > PE > 236ms > CE
+709ms ║Runtime (39477 bytes) successfully initialized in 323ms (v0.2.0e5.20170812) (706ms)
+710ms ║╔Execution stage started
+728ms ║║Comparison (string) :e329209b02524180269aeacb19563898: is_any_of (string) :beaf06d1244cff657bfc5a964ce25c62:,:e329209b02524180269aeacb19563898: = true (5ms)
+731ms ║║Cancelling condition #1’s schedules…
+732ms ║║Condition #1 evaluated true (12ms)
+748ms ║║Comparison (time) 51461909 is_between (time) 75600000 … (time) 18060000 = false (10ms)
+751ms ║║Condition #2 evaluated false (17ms)
+752ms ║║Condition group #null evaluated false (state did not change) (34ms)
+753ms ║║Piston execution aborted due to restrictions in effect
+772ms ║║Comparison (time) 51461934 is_between (time) 75600000 … (time) 18000000 = false (10ms)
+775ms ║║Cancelling condition #4’s schedules…
+822ms ║║Comparison (enum) off stays (string) off = true (3ms)
+826ms ║║Comparison (enum) off stays (string) off = true (3ms)
+831ms ║║Comparison (enum) off stays (string) off = true (2ms)
+835ms ║║Comparison (enum) on stays (string) off = false (2ms)
+839ms ║║Comparison (enum) off stays (string) off = true (3ms)
+844ms ║║Cancelling any timed trigger schedules for condition 11
+845ms ║║Cancelling statement #11’s schedules…
+846ms ║║Cancelling condition #11’s schedules…
+881ms ║║Comparison (enum) off is (string) off = true (3ms)
+885ms ║║Comparison (enum) off is (string) off = true (3ms)
+889ms ║║Comparison (enum) off is (string) off = true (3ms)
+893ms ║║Comparison (enum) on is (string) off = false (3ms)
+897ms ║║Cancelling condition #15’s schedules…
+906ms ║╚Execution stage complete. (196ms)
+914ms ╚Event processed successfully (914ms)
