I noticed that my pistons were not firing when trigger events were occurring so I wrote a very simple piston to test things. I see the trigger events in the ST IDE but it seems my pistons aren’t reacting to events. Any thoughts as to how I can get the house working again are appreciated.
As a note, I am aware of what happened this morning and upgraded to the WC release that was posted a few hours ago. Also:
- I upgraded to the release that was posted to Github this morning.
- My PC clock is correct.
- I’ve opened, edited and saved a number of pistons that aren’t running but that doesn’t help
- I see the event that should trigger the piston in the ST IDE log
- I don’t see any errors in the IDE log
Piston I am using for troubleshooting (posting the red version for additional clarity)
From the Piston Log:
11/5/2017, 11:10:47 AM +725ms
+0ms ╔Starting piston… (v0.2.0fb.20171026)
+329ms ║╔Subscribing to devices…
+333ms ║║Subscribing to French Doors.contact…
+426ms ║║Subscribing to Chandelier…
+427ms ║╚Finished subscribing (101ms)
+458ms ╚Piston successfully started (458ms)
From the IDE:
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:35 AM: debug Parse returned [French Doors was closed, French Doors was closed, French Doors was inactive, French Doors was 61°F, French Doors Battery was 63%, French Doors was -80 dBm, French Doors Signal (LQI) was: 96%]
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:33 AM: debug Parse returned [French Doors was closed, French Doors was closed]
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:32 AM: debug Parse returned [French Doors was -80 dBm, French Doors Signal (LQI) was: 95%, French Doors was -10,-1002,-1]
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:30 AM: debug Parse returned [French Doors was -80 dBm, French Doors Signal (LQI) was: 98%, French Doors was -9,-1002,9]
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:27 AM: debug Parse returned [French Doors was -79 dBm, French Doors Signal (LQI) was: 98%, French Doors was -6,-1002,5]
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:24 AM: debug Parse returned [French Doors was opened, French Doors was opened]
3f18f9ef-6ac4-4649-a46a-88680ff17fb7 11:12:24 AM: debug Parse returned [French Doors was active, French Doors was -80 dBm, French Doors Signal (LQI) was: 90%]
Edit: I created a second test piston. It also fails to run:
