Play Track does not work if optional volume is set
When I use a task to ‘play track’ on my Sonos speaker the speaker does not play if I put something in the optional Volume field. The same track plays just fine when the Volume is empty.
Same issue here. You have to set volume independently
This is a known issue and previous discussions in the ST community have concluded that this is a issue with the Device-Type Handler, not webCoRE. As noted, you can easily workaround this with a separate set level action.
Sonos is supposed to release a new SDK sometime this year, and perhaps that will allow development of a new DTH that can address this and other issues with the current one.
