Problem with switches mirroring another switches state (SOLVED)
I have two pistons that aren’t working. I’m not sure but they may be related to the DLST issues. I am running version ofc of the app. Both of these switches, each of a different type, have worked for over a year with zero issues. I have a simple piston that says when dimmer A changes away from off set dimmer B to 15%. The piston also tells dimmer B to turn off when dimmer A turns off. The other switch is the same scenario but it turns on/off a smart outlet to mirror a GE simple light switch. I’ve edited them slightly to try and “poke” them back to life but no go. My garage isn’t triggering my mimo relay when my Android presence arrives but I need to make sure that’s not a different issue. That garage piston has been working very well for over a year too. I can’t tell from the forum here if other people with switch problems have found resolutions yet. Thanks all.
~~~~~~~~~~~~~update
It’s all working again. I needed to upgrade to ofd. Something’s whacked with my setup as I have always gotten messages in the app telling me I need to update webcore but I didn’t get one for the latest release. I also have to manually update in GitHub. I’ll have to get to the bottom of that next.
