I’ve made a test piston and the logs indicate the calls to the device are being made. The device doesn’t always change mode based on a hue or CT parameter change. Perhaps this is a bug in the Hubitat virtual RGBW driver code.
WebCoRE logs
8/27/2023, 9:29:45 PM +65ms
+3ms ╔Received event [Grossland HE].time = 1693193385044 with a delay of 21ms, canQueue: true, calledMyself: false
+8ms ║RunTime initialize > 8 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 3 m:7 3 5)
+11ms ║Runtime (6728 bytes) initialized in 1ms (v0.3.114.20230809_HE)
+14ms ║╔Execution stage started
+39ms ║║Executed device command [Test RBGW].setColorTemperature(2700) (15ms)
+41ms ║╚Execution stage complete. (27ms)
+43ms ╚Event processed successfully (41ms)
8/27/2023, 9:29:43 PM +987ms
+3ms ╔Received event [Grossland HE].time = 1693193383966 with a delay of 21ms, canQueue: true, calledMyself: false
+8ms ║RunTime initialize > 7 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 3 m:6 3 4)
+10ms ║Runtime (6723 bytes) initialized in 1ms (v0.3.114.20230809_HE)
+13ms ║╔Execution stage started
+52ms ║║Executed device command [Test RBGW].setHue(0) (31ms)
+56ms ║║Executed virtual command wait [1000] (1ms)
+58ms ║║Requesting wake up at Sun, Aug 27 2023 @ 9:29:45 PM MDT (in 999ms) for 11 (st:12)
+61ms ║╚Execution stage complete. (47ms)
+93ms ║Setting up scheduled job for Sun, Aug 27 2023 @ 9:29:45 PM MDT (in 993ms)
+94ms ╚Event processed successfully (93ms)
8/27/2023, 9:29:42 PM +915ms
+3ms ╔Received event [Grossland HE].time = 1693193382889 with a delay of 26ms, canQueue: true, calledMyself: false
+8ms ║RunTime initialize > 8 LockT > 1ms > r9T > 1ms > pistonT > 1ms (first state access 3 m:6 4 4)
+10ms ║Runtime (6706 bytes) initialized in 1ms (v0.3.114.20230809_HE)
+15ms ║╔Execution stage started
+47ms ║║Executed device command [Test RBGW].setColorTemperature(2700) (25ms)
+50ms ║║Executed virtual command wait [1000] (0ms)
+52ms ║║Requesting wake up at Sun, Aug 27 2023 @ 9:29:43 PM MDT (in 999ms) for 7 (st:8)
+54ms ║╚Execution stage complete. (40ms)
+98ms ║Setting up scheduled job for Sun, Aug 27 2023 @ 9:29:43 PM MDT (in 994ms)
+100ms ╚Event processed successfully (97ms)
8/27/2023, 9:29:41 PM +868ms
+3ms ╔Received event [Grossland HE].test = 1693193381868 with a delay of 1ms, canQueue: true, calledMyself: false
+7ms ║RunTime initialize > 6 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 2 m:5 3 3)
+9ms ║Runtime (6639 bytes) initialized in 1ms (v0.3.114.20230809_HE)
+10ms ║╔Execution stage started
+17ms ║║Command optimization: Skipped execution of device command [Test RBGW].setLevel(100) because it would make no change to the device. (1ms)
+21ms ║║Executed virtual command wait [1000] (0ms)
+22ms ║║Requesting wake up at Sun, Aug 27 2023 @ 9:29:42 PM MDT (in 999ms) for 3 (st:4)
+24ms ║╚Execution stage complete. (14ms)
+63ms ║Setting up scheduled job for Sun, Aug 27 2023 @ 9:29:42 PM MDT (in 994ms)
+64ms ╚Event processed successfully (62ms)
Hubitat logs
dev:2572023-08-27 09:29:45.095 PMinfoTest RBGW colorName is Incandescent
dev:2572023-08-27 09:29:45.093 PMinfoTest RBGW colorTemperature is 2700°K
(missing Test RBGW colorMode is CT)
dev:2572023-08-27 09:29:44.032 PMinfoTest RBGW colorName is Red
dev:2572023-08-27 09:29:44.015 PMinfoTest RBGW hue is 0%
dev:2572023-08-27 09:29:44.013 PMinfoTest RBGW colorMode is RGB
dev:2572023-08-27 09:29:42.953 PMinfoTest RBGW colorName is Incandescent
dev:2572023-08-27 09:29:42.947 PMinfoTest RBGW colorTemperature is 2700°K
