There was a problem loading the dashboard data (August 25, 2020)
#144
I had a problem loading my dasboard, all of this night. Many of us had that today. I commented row 950. Cleared my browsers cash and cookies. Re-registered webcore dashboard and it works like charm.
Many thanks.
#145
I did that but mine is still not working.
Update: I’m finally going again. In addition to commenting out the 2 sets of lines as described above, I also did a “Clean up and rebuild data cache” for WebCore in the new app, That seems to have been the magic for me.
#146
In case you didn’t figure out the alexa switch, here is a link to the ST forum
#147
Hi Berg… use the device handler that teba provided a link to. Then be sure within the SmartThings app to open the Webcore Smart App and add the device to settings. It should be added as both an actuator and a sensor. It will then show up when using the Webcore dashboard and writing a piston
#148
Are we all still commented out or are we good to get back in the water (go to the repo version)?
#149
Hello all,
I had the same problem trying to login to Webcore. Thanks for this suggestion. I did not need to make a change in line 950 or in 5052-54. Just the trick of strong text“Clean up and rebuild data cache” for WebCore in the new appstrong text did the magic.
Thanks
Jomeg0
