I’ve been having this issue for a while but haven’t seen any response. Not complaining.
The second hub is a v1 at a different location. If I try to create a new piston or backup a piston that works from my primary hub I get this error and when you hit go home I have a pause piston with the name I gave it but then if I try to edit it, it goes right back to the dashboard.
I’ve totally deleted the webCoRE app multiple times but get the same issue. Could the v1 Hub be the cause of the issue.
