Updating WebCoRE and the pistons
What I want to know is when you update WebCoRE does this automatically update the pistons? The reason I ask is on the pistons it still says UI vision then the old number.
If it doesn’t how do we update them?
No, it does not. You need to login to the SmartThings IDE and go to both device handlers and the smart apps tabs. From each of those click on update from repo, then click on webcore. That will open another window listing all the updates for webcore. Put check marks next to each of them. Then in lower right corner make sure you Check publish and then update them. This needs to be done for both the device handler, there should be 1 update for that. And, the smart app, there should be 4 items there to update.
Hope that helps.
sorry @Gopack2 may not have made myself clear, I meant after I have done that.
Ahhh. Sorry, I misread. You might need to hard log off the app then reauthorise a new browser from the SmartApp in smartthings. It will give you a code You enter that in and it should get rid of that message
Done that aswell, WebCoRE is up to date its just the pistons that don’t seem to update? when you open them or view them, under the name it says UI version xxxxxx and that is a older version than WebCoRE.
Do you have more than 1 webcore SmartApp installed in smartthings? If so you may need to reauthorze browser for each.
yes i have 2 instances, one for the presence sensor and my main one.
You may need to reauhorize browser for each
done that too :frowning:
@ady624
Gru, sounds like a user needs you
Moved thread to: bug reports
was just about to tell you what version they all were, using my PC to read them but they are all right? its on my phone that they are wrong? it was my phone that i did all the hard resetting and reauthorizing too as well?
edit: i just re did the hard reboot of the webpage on the phone and reauthorized both instances again and its still saying v0.2.0ec.2017 (can’t read the rest) on the piston, but at the top of the page it says WebCoRE (v0.2.0f9).
