Using two lifx scenes with the same lights and smartthings button, won’t toggle between scenes when single pressed or double pressed
Single press turns lifx scene to scene 1 and double press turns lifx scene to scene 2
All other bulbs in automation are doing what is expected, but when button is toggled between single push or double push, the lifx scene will not toggle to the one I want it to toggle to. Stays the same as previous scene
