Webcore.co/re in browser Error
Keep getting “The requested URL /re was not found on this server.”, and a 404 error trying to reach “webcore.co/re” to register a browser so I can access and update my pistons. Also get the same error trying to access “webcore.co”. Anyone else having this problem?
Sorry found the proper way to access the dashboard. Please ignore this post.
So…what is the solution - I’m having the same problem?
Access “dashboard.webcore.co”
@storageanarchy and @saulf, where did you find that webcore.co/re link? I know that I’ve seen it before but can’t remember where it is referenced. Registration is done at https://dashboard.webcore.co but if there is a prominent broken link I’ll set up a redirect to make webcore.co/re work.
Dont remember where I found it but I would always use it to register the browser until this week when it comes up with “404” error. Then I found you need to use “dashboard.etc” to get into browser.
It is the link provided when you use the ST Mobile App, run WebCoRE and select “Register a new browser” - a screen pops up with the registration code and directions to go to webcore.co/re to enter it and register the browser…
I haven’t had any luck making webcore.co/re work again; instead I updated the message in the app to direct users to dashboard.webcore.co
