First off I want to say that I played with CoRE a bit about 2 years ago and ended up settling with basic ST routines to meet my automation needs. After installing and toying with webCoRE for a day or so, I am SUPER impressed. This has come a long way. The web interface is fantastic and makes it so much easier to build home automations.
Anyway, I acquired a few new devices recently and decided to make the push for more actual home automation. I now have several pistons running flawlessly for the most part. My only persistent issue is that Iām not able to get any push notifications to to my device.
Push notifications do not work on my mobile device. Iām running the latest iOS and the new Samsung Smart Things app. Smart Things Classic is not installed on this device.
Pistons with SMS notifications work as expected, but I would prefer the push notifications via SmartThings app. I have tried using both āSend notificationā and āSend PUSH notificationā actions with no luck. Additionally I have tried sending the notification as a Value and valid Expression (prefer expressions as I want to include device attributes). When I build a piston and add āSend SMS notificationā where I want to actually send a push notification, it works as expected. Which leads me to believe itās an issue with the webCoRE notification functionality or my device. I have tested the new Smart Things app and successfully received notifications from the Home Monitor module of the Smart Things app (leak sensor, etc). Full notifications are enabled for the Smart Things app on my device.
Again, I do not have the Smart Things Classic app installed or configured. Iām wondering if this might be the issue? I believe I installed webCoRE through the Classic app and never really used it. I have not yet gone so far to reinstall and reconfigure SmartThings Classic, but thatās my next troubleshooting thought beyond asking for help here.
A push notification to my phone.
My phone does not receive a push notification.
This is a simple example⦠The SMS sends but the push does not.
Logs are indicating that the notification was pushed as expected:
|+126ms|āāCalculating (string) Island light level is + (string) 77 >> (string) Island light level is 77|
|+132ms|āāExecuted virtual command [Corner Light].sendNotification (3ms)|
|+142ms|āāCalculating (string) Island light level is + (string) 77 >> (string) Island light level is 77|
|+161ms|āāExecuted virtual command [Corner Light].sendSMSNotification (12ms)|
|+164ms|āāExecution stage complete. (98ms)|
From above, I receive the SMS notification but not the push notification. This entire piston is just a basic example of my issue and not intended to use regularly. That said, the push notifications are not working at all in any of my pistons. I wasnāt able to find anyone else with this issue when searching, so I will continue troubleshooting and post my findings here.
