I am trying to set a variable with one of three numbers 3,1.5,0 to use as an offset to $sunset. The variable gets set fine, but when i put it into expression through offset, the vaule gets totally changed for all other timeframes than milliseconds…is this a bug, or am i doing something wrong…I have attached the piston and a simple example of how the number changes (not even using a variable) for anything other than milliseceonds.
PRESETS DONT WORK BECAUSE I AM TRYING TO VARY THE TIME ACTION BASED ON WHEN SUNSETS…IS THIS A BUG OR AM I DOING SOMETHING WRONG?
