@WCmore . Now that you gave that suggestion I am now remembering why I had to have the solar radiation reading of the weather station as an expression and not just use the standard ‘Physical Device’ category. It is because for some reason the solar radiation does not report back as a number. Take a look:
I’ll use the illuminance reading instead since this looks to be reporting as a number. This is measured in Lux and is a direct correlation to the solar radiation. I just have to figure out what the lux reading is at the 450 w/m2 solar radiation reading.
Whats sort of interesting about this, is that WeatherUnderground reports solar radiation of all the weather stations in the network and not lux so I was using that since I could correlate solar radiation to when it was sunny vs cloudy and I really cant do that with lux as easily.
I’ll just have to create a separate piston for the time being to send me the lux when the solar radiation is at, or around, 450 w/m2 to figure what lux to put in until I get a good handle of how the my weather station reports lux when it is cloudy vs sunny.
