Hi there. I’m working on a fairly large piston (15 chunks if I’m reading IDE correctly). When I try to save, the banner at the top of the page indicates, “Backup Bin Updated”, but doesn’t show the typically dynamic, “Saving chunk x of y”.
This behavior occurs every time I try to save. If I “Cancel” instead, then go back in to edit the piston, I get the message indicating there is a newer local version and I choose the local option in order to preserve my changes.
I have tried the recommendations here.
When I import the restored piston from the backup code, I’m able to get my latest changes, however when I try to save the restored version, I get the same message “Backup bin updated”, and I’m back in the same loop of despair. Interestingly, there is no “Cancel“ option from within the restored piston.
I’d appreciate any ideas on how to overcome this situation. Thanks!!!
