I have tried both change to off and turn off both stop after a few days
Change to off and turn off not woking
Please post this in the Piston Design Help category, and fill in the fields like below. I have absolutely no idea what you are asking or expecting. Happy to help, but need details to be effective.
milhouse
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
it was posted Switch change working every other time
then i moved it bug because no matter what i tried off stops every few days
Put the wait before line 30 and then set that with
task cancellation policy to never cancel. Also, I don’t see Line 18 as subscribing to the Switch 1 switch event.
I thought momentary switch wasn’t working for you in a previous post? Why not just use a regular switch and try the piston above.
i am test code from above will let it run a few days and see how it works
it looks like Alexa is ok with it now
i am just trying to keep it simple
