For the last several days, i’m having issues with events not firing. Most commonly it’s Motion == Inactive. SmartThings displays my motion sensors as “No Motion” and reports them switching to inactive in “Recently”, but the piston is not picking up that event, and therefore my lights never turn off. This issue is intermittent, but is occurs fairly regularly throughout the day (4-5 times a day in both bathrooms). Is there a current known issue on either the WC or ST side, or a workaround?
EDIT: More info - i caught the error in the ST live log, it’s pasted below. Does anyone know how to resolve this? Seems like it may be a connectivity issue on the Samsung side (surprise surprise), but not 100% sure.
85213610-8a28-4465-9bee-d8731530bb33 8:33:42 PM: error org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: could not execute query; uncategorized SQLException for SQL [select this_.id as id54_0_, this_.version as version54_0_, this_.date_created as date3_54_0_, this_.`key` as key4_54_0_, this_.type as type54_0_, this_.value as value54_0_ from server_config this_ where this_.`key`=?]; SQL state [null]; error code [0]; [SimpleAsyncTaskExecutor-75] Timeout: Pool empty. Unable to fetch a connection in 30 seconds, none available[size:50; busy:0; idle:0; lastwait:30000].; nested exception is org.apache.tomcat.jdbc.pool.PoolExhaustedException: [SimpleAsyncTaskExecutor-75] Timeout: Pool empty. Unable to fetch a connection in 30 seconds, none available[size:50; busy:0; idle:0; lastwait:30000]. @line 1141 (processSchedules) 85213610-8a28-4465-9bee-d8731530bb33 8:33:12 PM: info ║ Setting up scheduled job for Mon, Oct 29 2018 @ 8:34:11 PM PDT (in 59.964s), with 4 more jobs pending 85213610-8a28-4465-9bee-d8731530bb33 8:33:12 PM: trace ║╔ Execution stage complete. (113ms) 85213610-8a28-4465-9bee-d8731530bb33 8:33:11 PM: trace ║╚ Execution stage started 85213610-8a28-4465-9bee-d8731530bb33 8:33:11 PM: trace ║ Runtime (58311 bytes) successfully initialized in 63ms (v0.3.108.20180906) (146ms) 85213610-8a28-4465-9bee-d8731530bb33 8:33:11 PM: info ╚ Received event [Bathroom Motion].motion = inactive with a delay of 547ms 85213610-8a28-4465-9bee-d8731530bb33 8:33:09 PM: error org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: could not execute query; uncategorized SQLException for SQL [select this_.id as id56_0_, this_.version as version56_0_, this_.date_created as date3_56_0_, this_.`key` as key4_56_0_, this_.type as type56_0_, this_.value as value56_0_ from server_config this_ where this_.`key`=?]; SQL state [null]; error code [0]; [SimpleAsyncTaskExecutor-117] Timeout: Pool empty. Unable to fetch a connection in 30 seconds, none available[size:50; busy:3; idle:0; lastwait:30000].; nested exception is org.apache.tomcat.jdbc.pool.PoolExhaustedException: [SimpleAsyncTaskExecutor-117] Timeout: Pool empty. Unable to fetch a connection in 30 seconds, none available[size:50; busy:3; idle:0; lastwait:30000]. @line 1141 (processSchedules)
Below is a green snapshot of the piston, it’s been working fine for about 6 months without issue. Below that is a log snippet, you’ll see that there’s no event with motion changing to inactive - the ST app reported the motion sensor changing to No Motion at 11:05am, but there’s no corresponding event in the log.
10/29/2018, 11:07:08 AM +304ms
+1ms ╔Received event [Home].time = 1540836429640 with a delay of -1336ms
+319ms ║Runtime (58298 bytes) successfully initialized in 155ms (v0.3.108.20180906) (316ms)
+320ms ║╔Execution stage started
+454ms ║╚Execution stage complete. (134ms)
+457ms ╚Event processed successfully (456ms)
10/29/2018, 11:04:08 AM +111ms
+1ms ╔Received event [Bathroom Door].contact = open with a delay of 1046ms
+235ms ║Runtime (58300 bytes) successfully initialized in 135ms (v0.3.108.20180906) (232ms)
+236ms ║╔Execution stage started
+273ms ║║Executed virtual command setVariable (4ms)
+280ms ║║Executed virtual command setVariable (3ms)
+287ms ║║Executed virtual command setVariable (3ms)
+1269ms ║║Executed [Bathroom Light].on (974ms)
+1446ms ║║Executed [Bathroom Light].setLevel (154ms)
+1568ms ║║Executed virtual command setVariable (4ms)
+1575ms ║║Executed virtual command setVariable (3ms)
+1583ms ║║Executed virtual command setVariable (3ms)
+1598ms ║║-----====>>> POOPED: false
+1599ms ║║Executed virtual command log (2ms)
+1607ms ║║Executed virtual command setVariable (3ms)
+1614ms ║║Executed virtual command setVariable (3ms)
+1627ms ║║warnDelay: 900
+1628ms ║║Executed virtual command log (2ms)
+1640ms ║║offDelay: 1200
+1642ms ║║Executed virtual command log (1ms)
+1646ms ║╚Execution stage complete. (1410ms)
+1648ms ║Setting up scheduled job for Mon, Oct 29 2018 @ 11:07:09 AM PDT (in 179.882s)
+1659ms ╚Event processed successfully (1659ms)```
