I noted yesterday that I thought this might be a ST issue, and the reason for that suspicion was that a given piston did not always fail in quite the same way twice. However, the timing relative to the update was oddly coincidental and there were (and as yet, are) no issues posted on status.smartthings.com.
All that notwithstanding, this is a very serious issue that is wreaking havoc with a number of critical pistons, causing them to delay, fail, or randomly refire. It is for me at least easily reproducible, though as I mentioned the behavior can vary somewhat from one execution to the next. Below is an extraordinarily simple piston, fired once by clicking the ‘Test’ button, and you can see the results in the subsequent log.
![piston](https://community.webcore.co/uploads/default/original/2X/4/48f2d0b91115f2e571ccd5a2fca85741746690b7.png)
