I was just getting a grasp on creating my own Pistons and then up and sold my house, then moved to a new one. Haven’t started setting up my HA gadgets yet and decided now’s the time for some cleanup in the SmartThings app.
Tried to update my address in SmartThings and no matter what I did, it wouldn’t accept it. It’s new construction and not on maps yet. In a 1 AM sleep deprived state, I made a bonehead move and deleted my “Home” in SmartThings just trying to fix the address.
After I regained the ability to hold my lunch again, I decided since I messed it up, I’ll stick with only the new app. Got WebCore back and realized my Pistons are all gone.
Logging into WebCore, I can’t find any old Pistons. I am not sure how closely tied to the SmartThings “Home” they are, but they seem lost. Just wondering if anyone knows of a way to tell?
I’ve searched the forum already and tried what I could, but coming up empty so far. If they’re gone, so be it. Just wanted to use what I made for my own educational documents for making new Pistons.
Thanks
Find Lost Pistons?
If you used the automatic backup feature we should be able to restore your pistons. The data is encrypted so I can’t help find any specific pistons, but it should be possible to retrieve all of your backup codes. The codes are associated with your SmartThings account ID, so they survive deleting a webCoRE instance.
Please sign in to the webCoRE dashboard for your new webCoRE install and create two new pistons, then send me a private message with the backup codes for those pistons. The two codes should help to unambiguously identify your account and allow me to retrieve the backup codes for the lost pistons.
These private backup codes are encrypted with the account id, so the main reason that webCoRE advises not to share them is that no one else can make use of the code.
Is there any way to recover a piston I accidentally uninstalled without the backup pin?
Deleted wrong instance - any way to recover
Lost Pistons migrating from Classic app to new
Webcore hoplelessly corrupt
Can't Restore Piston with Backup Code
Cant install WebCORE Smartthings new app or classic
@ipaterson I have a similar problem, WebCore was deleted by mistake and I don’t have the codes written although all pistons had auto backup. Will you be able to help if I send you 2 codes for newly created pistons? Thanks in advance!
@ipaterson I find myself in the same boat, hoping you could help me recover my deleted pistons (pretty sure I had auto backup turned on, anyway. I don’t know that I can PM you, not sure that I have enough posts. @webCoRE_Minions
I had to uninstall and reinstall Webcore, it created a new instance and now am unable to access the old instance. I did have auto back up on but I made the mistake of not thinking I needed a back up. If there is anyway anyone can help me that would be wonderful and amazing.
Also, I just made this account in order to post this message and have no idea how to PM or if I can PM but I did create the two blank pistons mentioned in previous posts. But really, I just need the old instance to be my current instance.
Thanks!
